[Z06] Ripper Shifter-- necessary
Old Oct 17, 2001 | 08:50 PM
Corpvette's Avatar
Corpvette
Default Ripper Shifter-- necessary
I am planning the mods on my Z before I get it. I've heard about the ripper shifter-- what is its advantage, and would you recommend it?
Old Oct 17, 2001 | 09:05 PM
VetterMan's Avatar
VetterMan
Default Re: Ripper Shifter-- necessary (Corpvette)
Shorter throw = faster shifts ... no missed shifts either! It's a must have mod!:D
Old Oct 17, 2001 | 09:51 PM
Power Shifter's Avatar
Power Shifter
I would recomend it IF your going to power shift. The springs are much stronger and gates shorter but thay can be a pain if you are regularly in stop and go trafic. Nothing wrong with the stock shifter if your not raceing.IMHO Ric
Old Oct 17, 2001 | 10:13 PM
Z06jerry's Avatar
Z06jerry
I just installed one. I petty sure I will be taking it out again very soon. IMHO, the effort is to high for regular non-competeition use. I'm also pretty sure I can shift as fast with the stock shifter. The Ripper does feel more precise but it transmits A LOT of noise into the car. After I removed the stock shifter I observed that it has a 2 piece shaft with a rubber isolation bushing built into it to reduce resonances. The B&M DOES NOT have this feature. To be honest I never had a problem power shifting with the stock shifter, I was hoping for an improvment. but the Ripper is not for me. :sad:
I'll give anyone in my area a heck of a deal on a slightly used one!
Old Oct 17, 2001 | 11:44 PM
Bleck's Avatar
Bleck
Default Re: Ripper Shifter-- necessary (Z06jerry)
Just drove my first Ripper last weekend in the very slightly used Z06 that I'm going to purchase (2002 order canceled). The effort is probably at least 10 times higher than any other stick shift I've ever driven, but even so, it's not bad. I plan on leaving it in the car (seller is providing original shifter as well). It gives a remarkably short throw, and feels much higher quality than the stock unit. The shifts just feel better, and I don't mind getting a little bit of a workout while I drive.
Oh yeah, I've heard that some have replaced the stock Ripper springs with lighter effort ones.
Old Oct 18, 2001 | 08:56 AM
ADE 1000's Avatar
ADE 1000
I love my Ripper, the effort does not seem that high to me and the feel is greatly improved. The noise is the biggest negative, but it is bearable. The much more precise feel and shorter throws are worth putting up with the noise.
Old Oct 18, 2001 | 11:33 AM
EdwardETraylorIII's Avatar
EdwardETraylorIII
Default Re: Ripper Shifter-- necessary (ADE 1000)
The noise is easily combatted if you use some dynomat to install the piece with. I have ZERO noise <quieter than stock> because I spent an extra 20 mins and $10 to install dynomat over the base of the ripper.
As far as difficulty shifting, well, it wears down over time and gets a lot easier. Combine that with the fact that your arm gets stronger and it's not difficult at all. Though, I do workout so maybe that's why I've never thought twice about it.
For those that can't stand the ripper I recommend the Kirban KwikShifter. It's OK and isn't hard to shift. Certainly more accurate than the stock sluchstick (shifter).
Old Oct 18, 2001 | 09:43 PM
Z06jerry's Avatar
Z06jerry
Default Re: Ripper Shifter-- necessary (EdwardETraylorIII)
Can you explain how you wrapped the base? My noise comes from the top of the shifter and increases when I touch the **** with my hand. It is really loud above 4000 rpm.
Jerry
Old Oct 18, 2001 | 10:02 PM
C5TECH's Avatar
C5TECH
Default Re: Ripper Shifter-- necessary (Corvette)
The stock shifter is a POS. The Ripper is much more stout and accurate. I drive daily with it, easy shifts. I have had my Ripper for about a year with a Kirban billet shift ball. There is no noise (no Dynamat needed). The springs do not increase effort in 1-2, 3-4 etc. The shaft is shorter and fulcrum is higher so if you want an easier shift just rotate the ball up to the top of the threads.
The real effort is caused by the M6 tranny. It is as close to a truck unit as you will find. I think GM needs to consider another vendor other than Tremec/TTS. Also syn. ATF will reduce shift effort will no ill effects.
Old Oct 19, 2001 | 12:31 AM
VetterMan's Avatar
VetterMan
Default Re: Ripper Shifter-- necessary (C5TECH)
Well said!
To Ripper Shifter-- necessary
