Am planning on doing both a road force balance on all four tires, and getting the car aligned.
A couple of questions:
1. Which should be done first? Balance or alignment.
2. I want to reduce the possibility of cupping, while not totally destroying the cars' handling. So how should I have the car aligned? What specs should I be talking to the tech?
Thanks.
Mike
1. Makes no difference. One has no effect on the other in terms of adjustments.
2. No techie here but if the place you take it to doesn't know, go somewhere else IMO.
I've been taking my vehicles to a brake & wheel shop here in town for 40 years. I trust them completely. Put new tires on the Ranger. Had them check the alignment. No adjustment needed. No charge. That's service!
Thanks for the replies. I still would like to know what alignment specs I should ask for, to provide for the least wear on my new $1600 run-flat tires, while still providing a degree of handling. Since we can't rotate the tires, I want to do everything I can to assure the longest (and smoothest) tire life I can.
Thanks.
Mike
There have been a number of threads on this subject. I'm going to have my '02 checked next week. I've noticed too much wear on the inside of the front tires. It has been suggested by others that camber be adjusted to 0 to correct this. I think the factory specs call for a little negative camber which could be the cause of this wear pattern.
if you want to allign the car perfectly, have the allignment done with you in it. if your a large person, that WILL affect the allignment. i always do this, as i weigh, 225lbs.
178 lbs. I don't think I have much effect on the tire wear. From what I understand tire cupping is caused by bad alignment. Right? Only 6 thousand miles on my new tires and I am beginning to hear that sound again (previous tires were cupped with only 20,000 miles). Car has been aligned once last spring just after getting the new tires. Car was set at "factory specs" at my local Chevy dealor. Not happy with their results.
Mike
you can rotate the front tires.... you just need to buy them at a shop that provides lifetime mount and balance as part of the purchase package....( well you can do it anyway , you just have to pay a for a few more mount and balances)
IF you start getting inside edge wear have the front tires demounted and put on the opposite side....
Both the left and right side of directional tires is identical...
So the inner edge of the left tire after the rotation becomes the outer edge of the right tire.....
p.s. ... cupping isn't caused by camber, cupping is caused either by bad shocks or incorrect toe.
I think whaqt you are concerned about is uneven wear across the tread with excessive inner edge wear which is casued by negative camber.
Thanks.
Mike
Oops, just noticed bb609s' added edit. Thanks bb.
If ya gotta bring your own spec's with you......seems to me you shouldn't let them touch your car....Ya know?
Well, Groucho, I agree with you. But if it is the only show in town, well, what can you do? Here is what I am noticing and what concerns me:
1. Beginning to notice that rhythmic sound of uneven tire wear...just slightly. Only six thousand miles on the tires and I shouldn't notice anything.
2. When I drive and look in my rear view mirror, I can see the defrost wires in the rear window slightly moving back and forth from side to side, seemingly at the same rate as tire rotation. The faster I go, the faster the side to side movement, until it is a slight blur. At a slow speed, the motion is just as slow. Granted, the motion is not much, but it shouldn't be there at all, should it?
So, hence my concern.
Therefore, I am going to get the tires road force balanced and the car realigned (again). From what I have read on this forum, most alignment techs will align the car according to Chevy specs and those specs are set up for "proper handling" with the corvette. But in addition to the handling, it can also cause more wear on the tires. Is this true? How much more wear?
Mike
