I had callaway headers (shorties), throttlebody (including MAF?), and Honker installed
as a co-incidence or since then, I seem to get some unusual console messages
Ill see low washer fluid alert, check it and its right to the top
ill see low coolant, but i just had the radiator flushed and replenished, not more than 800 miles ago
altho, i also had euro lights installed for UK compliance,
and they pulled a (few) fuse(s) (in regards to turning off the amber running lights up front)
is there any logical correlation for these things?
the low coolant and low washer fluid lights seem to be a problem with the sensors, maybe tehy were unplugged for your install and not properly plugged in, worth giving a look.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I agree - and disabling the DRLs is just 1 fuse - not "a few". The only thing that stops working when you pull that fuse is the rear approach lights when you unlock the doors - nothing else.
I've had my DRLs disabled for 2 1/2 years with no problems.
