I wanna know where you guys have you Z service at? I really don't want to take it to a Chevy Dealer, as all I heard is bad news from them. Are there any shop that service just the corvette?
Where? In my own garage. Why spend the money taking it in to a dealer or mechanic for routine maintenance? These cars are so easy to work on, it's a waste of money otherwise.
Just had my 30k done at a local dealership, went that route as the car is still under warranty and a lot gets changed. After hearing all the horror stories I was a bit worried but it all went quite well. They did a good job, used the fluids I supplied (reduced the servicing cost), replaced both headlight motors (again), and honestly the car seems as good if not better than before (actually runs cooler & I'm back up in the 25-27mpg range). Car seems as spirited as ever with all the power I felt when I first got her with 4600 on the clock. But... For general maint like oil change, clutch fluid, etc. I normally do that myself either at home or at the base auto hobby shop. As mentioned the car is pretty easy to work on
I use my local dealer for things covered by the GMPP. Stuff not covered by GMPP I do myself or in the case of oil changes I go to Jiffy Lube. The dealer just replaced 4 tie rod ends for me this last week. Bill without GMPP would have been $725 but was $0.00 under the plan. Cost of doing it myself with parts from Gene Culley would have been close to $400.
What part of Nor Cal? I just moved from that area last year back to UT. If you are anywhere near Fairfield I would highly recommend Woodard Chevrolet. I used them a couple of times and they were great to me. Had an EBCM issue and they stepped right up to fix it and gave me a smokin deal for it as well. The parts manager is named Rich and he is a real good guy and drives a somewhat "massaged" torch red Z06 that is quite entertaining. Good place!
i'm located in Nor Cal
Call Pat at Precision Motive (510) 886-0789 in Hayward. They're a full service shop specializing in Corvettes
