Maplights (Replacement Solutions)
Old Apr 26, 2007 | 11:59 PM
nonsuchpro's Avatar
nonsuchpro
Default Maplights (Replacement Solutions)
Hey All,
Did the footwells and cargo area today, on to Maplights
Are there any plug and play LED arrays for the Maplights on the electrochromic mirror that don't require soldering? I don't really want to go with Spdkilz's solution of removing the bulbs and soldering in the new ones.
I've read all the other posts on this topic but I don't really grasp the concept of the recommended "festoon" bulb on autolumination's site. The festoon looks like it has metal tips on each end but my current setup is a circuit board with 6 LEDs and a power wire clipped on. Are they for non-electrochromic mirrors only?
So I guess the real question is... Can I buy RED LED arrays that have the same power socket to plug the power cables into?
Thanks in advance
Old Apr 27, 2007 | 03:50 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Check these out... He didn't list the source though.
http://forums.corvetteforum.com/show....php?t=1685033
The Festoons were changed over to LED arrays sometime in 2000 I believe.
Old Apr 27, 2007 | 12:40 PM
nonsuchpro's Avatar
nonsuchpro
Yeah he did the Spdkilz solution which I'm trying to avoid.
Old Apr 27, 2007 | 02:11 PM
SilverC54me's Avatar
SilverC54me
Default Thats the only way
The only way to change the LED's in the Electrochromatic mirror is to unsodder the old and sodder in the new. The mirror, radio and HVAC controler all require soddering to change the LED's.
Gary
Old Apr 27, 2007 | 03:07 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Thanks in advance
Sound likes a winner. You'd be the first...let us know how it turns out
Someone's gotta go first. This is just considered R&D around here...
EDIT::: Just thought of this too... you could just get a regular mirror installed and replace those bulbs with 211-2, 44mm, 9 LED bulbs...
Old Apr 27, 2007 | 08:36 PM
tstar's Avatar
tstar
Or do something off the wall like I did and cut small pieces of Red window film and put it behind the lenses... cheating? I don't know... but it's freaking Red!!!!
Old Apr 28, 2007 | 01:27 AM
nonsuchpro's Avatar
nonsuchpro
Thought about that for a minute.... but I like the features of electrochromatic mirror.
Old Apr 28, 2007 | 01:30 AM
nonsuchpro's Avatar
nonsuchpro
[/IMG]
Thats what I have on there right now.... I cut 2 squares out of a red DJ lighting gel.... worked good, it's just not very bright.
Love the look of yours, I used your pic in my last post about "footwell and cargo leds" as a basis of what I ultimately want mine to look like.
Old Apr 28, 2007 | 01:32 AM
tstar's Avatar
tstar
Do you know the measurements of the board in the mirror now? Look at this... Scroll all the way down the page;
http://www.superbrightleds.com/cgi-b....21379&next=50
Old Apr 28, 2007 | 01:33 AM
tstar's Avatar
tstar
Damn, I got my 1 minute of fame and missed it? Cheese and Rice!!!!!!!
Old Apr 28, 2007 | 01:42 AM
nonsuchpro's Avatar
nonsuchpro
Do you know the measurements of the board in the mirror now? Look t this... Scroll all the way down the page;
Unfortunately no, but mine looks exactly like this:
Old Apr 28, 2007 | 01:47 AM
nonsuchpro's Avatar
nonsuchpro
Anyone know if replacements bulbs/circuit boards can be bought from GM? Like if bulbs burn out? If I'm going to do any soldering, I'd like to have a backup and keep a set of stock ones anyway.
Old Apr 28, 2007 | 01:54 AM
tstar's Avatar
tstar
You can probably get a used mirror off of Ebay cheaper... The more I look at the stock board, that link I sent you might work. You'd have to swap plugs though...
Old Apr 28, 2007 | 02:08 AM
nonsuchpro's Avatar
nonsuchpro
Which bulb on that link? 3022-x9 LED Festoon bulb? I didn't really see one that could work.
Old Apr 28, 2007 | 02:17 AM
tstar's Avatar
tstar
Scroll all the way down to the bottom of the page, it's a universal PCB w/LEDs and a variety of plugs...
Old Apr 28, 2007 | 02:47 AM
SilverC54me
Sorry to say that the universal PCB is too big. There are 6 5mm LED's in a tight pattern on each side. There is just enough room for the original circut board. That being said, this mod was the first of the LED installs I did. It took me all of an hour to replace the LED's.
My recomendation would be to replace the factory LED's with 8000mcd White LED's.
Gary
Old Apr 28, 2007 | 02:58 AM
nonsuchpro's Avatar
nonsuchpro
Gary
I'm doing RED LEDs.... do you recommend 5mm 8000mcd for those as well?
Which one off this page http://www.superbrightleds.com/leds.htm
To Maplights (Replacement Solutions)
