[Z06] maintenance, changing fluids?
Old Apr 28, 2007 | 11:52 PM
GCadby's Avatar
GCadby
Default maintenance, changing fluids?
My Dad has an 2004 ZO6 that has been garage kept from the day he bought it. It only has 600 miles on it. Can anybody tell me what fluids should be changed if any?
Old Apr 29, 2007 | 01:17 PM
kbreese's Avatar
kbreese
With only 600 miles I don't think you need to change anything, except maybe the oil. And I'm sure you know that gas will go bad if it sits to long so you either need a stabilizer or to make sure a tank is run through it atleast every 3-4 months I would think, but I'm no expert. other than that, just follow the owners manual.
Old Apr 29, 2007 | 02:22 PM
dwjz06's Avatar
dwjz06
Dogface
St. Jude Donor '15, '17
Brake fluid for sure. After sitting for some years there could be water in the system. Every year is best every two for sure. The others can probably wait. Don
Old Apr 29, 2007 | 03:34 PM
slong's Avatar
slong
Extract the clutch slave for sure also. Syringe works well. Ranger has plenty of info on this subject. For some reason a black viscous rubber looking sludge develops, but not sure about one with low miles like pops.
Old Apr 29, 2007 | 03:44 PM
kbreese's Avatar
kbreese
i was going to mention his siphon procedure, but figured with 600 miles the fluid should still be perfect. The only issue is if it got water in it or something similar to what dwjz06 was saying with the brake fluid.
Old Apr 29, 2007 | 04:15 PM
GCadby's Avatar
GCadby
Thanks guys, we'll look into it.
Old Apr 29, 2007 | 09:46 PM
TEXHAWK0's Avatar
TEXHAWK0
I would not let antifreeze stay in the car for more than 3 or 4 years, even DexCool.
You still need corrosion inhibitors in the cooling system even if you are not driving it.
By the way, if it only has 600 miles, why did he buy the car????
Old Apr 30, 2007 | 11:45 PM
slong's Avatar
slong
I'm thinking pops should hand over the keys to you!
My kid is prob thinking the same thing; ain't going to happen.
To maintenance, changing fluids?
