Column Lock-Fuel Shut down bypass....
Anybody else had this same problem?
Yes, I've done plenty of searching on here and know alot about the CLB and service column lock problems but did not see anything much about the ability to fix the fuel shutdown.
If the CLB had been put in and the recall not done then you would have no problems. There's almost no point in putting in the CLB after the fact because the fuel issue still screws you.
So would the fuel-shut off still be fixed under the terms of the recall? I already had the recall done once in 04 but apparently the fuel shut down still has issues. I'm gonna call the dealer 1st thing Monday but I'm sure they won't want to fix any of it for free even if it is part of the recall. Is there a way to reset the fuel shut down problem I'm having now?
Russ Kemp
I just unhooked the battery. I'll give it 30 mins and try it again.
What choices do I have?
1) tow it into the dealer and they will most likely charge me to fix it?
2) buy an HP tuner and try to figure out how to bypass the fuel shutdown functionality?
3) any other suggestions?????
If you had the last recall, the lockplate has been removed so the column cannot lock, but you need a working relay (or actuator) in the system to satisfy the BCM so it does not cut the fuel.
As a way to make the car driveable until you can bypass the system, try reconnecting the column lock actuator. If you had a working actuator before the recall, you should be able to reconnect it and drive the car without the fuel being cut off.
Laurie
This column lock hell is making me crazy guys. I keep posting, answering emails and phone calls and the problems just keep coming.
Once the earlier recalls were done, you have the fuel cutoff problem. You've just traded off one tow bill for another. In one case your column lock failed to unlock and you can't steer the car and in the other case your column lock failed and your fuel is now cut off. One post said had you installed a CLB and never had the recall done you'd be in great shape. I agree with this.
Many have had one or more recalls done and now they're on the path to column lock hell. Many purchased used vettes and are totally unaware of any issues...they must read and learn.
So starting from here and not knowing exactly what's been done to your car, what should you do?
1. Call the dealer and find out what recalls have been done to your car.
2. Remove the knee bolster under the steering column and inspect your wiring harnesses. The K Harness relay is located on the left side of the steering column. It plugs into a 4-wire connector(*) on the right side of the steering column attached to the horizontal metal bar under your column. NOTE: if you've had the additional relay mod installed, this connector will have white, purple, green, black; if it's stock, it will be orange, purple, green black. The K-Harness also splits off and connects to the column lock motor inside your steering column (orange, purple, green, black). If your column lock motor connects directly into the connector(*), you have not had any mods except possibly for PCM re-programing.
If you've had the recall mods and now you're getting the pull and service message, your fuel is probably being cut off and you can't drive your car even if you column is not locked. You can sometimes save yourself a tow bill by connecting the column lock motor directly into the wiring harness under your dash and thereby removing the K Harness from the circuit. This assumes your column lock motor is still good.
In the end, there is only one solution....install the CLB.
I am interested in finding out more about the fuel cutoff removal using HPTuner. Can anyone verify that this is fact and what parameter needs to be changed?
Cardinal Rules for Column Lock Hell:
1. DO NOT take it to the dealer
2. Be proactive and get a CLB installed.
3. Ask for help if you need assistance. There are many forum members on this forum that can help. I have a documentation package with photos that many will find helpful.
Best of luck to everyone.
cscokd@gmail.com
John
Even if your battery started your car, it may be low enough to cause issue. I accidentally left my radar detector on for a few days and this ran down the battery which aggravated the column lock. Take some time and read the column lock posts at the top of this forum. Depending on wether you have a m6 or an a4 the fixes and issues are different. The column lock bypass is not a perfect fix either. There are posts about dependability and bcm problems from them. Personally if I had a mn6 I'd use the clb fix. If I had a a4 I'd do the recall. Hope this helps.....
Russ Kemp
My A4 apparently has the recall done. I actually bought a CLB, but have not installed it because I didn't want to goof up the recall. I'm keeping this on file for if (probably when) it gives trouble.
Thanks,
Tim Glover
