Tree Sap
Old Apr 30, 2007 | 05:22 PM
photoguy's Avatar
photoguy
Default Tree Sap
Posted in care care but no replys.
What do you recommend for removing tree sap from my mag red with clear coat?
Old Apr 30, 2007 | 05:37 PM
rws.1's Avatar
rws.1
I have used Turtlewax bug and tar remover when I was in a pinch... it did an OK job, but took a few attemptes to get pin sap off the paint.
I have also used WD-40, that does a good job but strips the wax.
I have also used Stoner's Tarminator which is my preferred solution
Old Apr 30, 2007 | 05:38 PM
xwing's Avatar
xwing
I'd use the "Bug & Tar remover".
Old Apr 30, 2007 | 05:42 PM
02MillenniumVette's Avatar
02MillenniumVette
Goo Gone should work but then you would have to get that off of your car also.
Old Apr 30, 2007 | 05:43 PM
5ltrEATER's Avatar
5ltrEATER
I'd go with a bit of WD-40... Works like a charm -- just rewax afterwards!
Old Apr 30, 2007 | 05:45 PM
02MillenniumVette
Hope you learned your lesson now about parking near a pine tree.
Old Apr 30, 2007 | 06:40 PM
jayr2k's Avatar
jayr2k
If its a really stubborn stain use a scratch remover like ds27
Old Apr 30, 2007 | 06:41 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
This did the trick for me. Sap does suck though.
Old Apr 30, 2007 | 07:17 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
"Stoner's" also makes a bug/tar remover... works great on sap.
Old Apr 30, 2007 | 07:25 PM
Evil One's Avatar
Evil One
Old Apr 30, 2007 | 07:38 PM
TomZ's Avatar
TomZ
Works great.
Old Apr 30, 2007 | 07:43 PM
6 Shooter's Avatar
6 Shooter
Turtle Wax Ice does a pretty good job with Tree Sap and Road Tar also.
L8TR - D
Old Apr 30, 2007 | 08:40 PM
rtagz's Avatar
rtagz
Cruise-In IX Veteran
clay bar, with a little bit of car wash as lubricant. if that doesn't work, try a few drops of dawn with the clay bar. but you will most likely have to reapply your polish/sealant/wax.
Old Jun 3, 2007 | 03:12 PM
nutseynut7's Avatar
nutseynut7
Just wash with really cold water
Old Jun 3, 2007 | 03:16 PM
Z28TOZO6's Avatar
Z28TOZO6
this is going to sound funny but try some mayonnaise, some old tree cutter guy showed me that. when he was cutting pine trees he would use it to get the sap off his hands.
Old Jun 3, 2007 | 03:24 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I would wash the car with hot water first. You could take a towel soaked in hot water and lay it on the bad spots. Should melt the goo and come right off with a followup wash with one of the car washing detergents.
Old Jun 3, 2007 | 03:41 PM
YeloFevr's Avatar
YeloFevr
I made the mistake of parking under a sappy tree in my other car. A clay bar and lubricant did the trick, but it took a VERY long time to get all of the sap off. It felt like I had tennis elbow afterwards, too!
To Tree Sap
Old Jun 3, 2007 | 04:56 PM
WetteVette's Avatar
WetteVette
Well, there you go!
Take your pick!
Old Jun 3, 2007 | 07:09 PM
OzzyC4's Avatar
OzzyC4
Vegetable oil
Old Jun 3, 2007 | 08:39 PM
J Z06's Avatar
J Z06
you're not crazy for suggesting that. i've heard that one also.
hot hot water might loosen it. 3m general purpose adhesive cleaner would do the trick. tarminator should help a bit and lastly...clay bar.
AVOID parking under pine trees(if you can).
