headlights
Old Apr 30, 2007 | 08:06 PM
istsme98's Avatar
istsme98
Default headlights
Is there a special tool for the headlight adjustment? Thanks in advance
Old Apr 30, 2007 | 08:09 PM
jdmvette's Avatar
jdmvette
Night Owl for life
use a torx socket, not a torx bit (you can use both).
find the right size and turn the golden rod that is underneath the light housing clockwise to raise, counter to lower.
Old Apr 30, 2007 | 08:15 PM
MUKAK's Avatar
MUKAK
Old Apr 30, 2007 | 08:16 PM
istsme98's Avatar
istsme98
Thanks a bunch!!!
Old Apr 30, 2007 | 09:35 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Gotta love this forum!
Old Apr 30, 2007 | 10:37 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Be careful, these adjusters strip easy. If you strip it you have to buy a headlight assembly or get lucky finding parts.
If it does not move easily, you'll have to dis-assemble and spray some lubricant on the adjuster connections. Work it slowly or you may strip it like I did, even though I lubed it.
Old May 1, 2007 | 07:51 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Be Careful!
Old May 1, 2007 | 09:55 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Do the fogs while you are at it, it makes a big difference.
http://www.c5forum.com/diy/fog_lamps.php
To headlights
