Best Price for gears.
Old May 1, 2007 | 07:36 PM
vettegator005's Avatar
vettegator005
Default Best Price for gears.
I would like to see what the best deal on 3.73 or 3.90 gears is? I cant find any for a resonable price but ive only found two places that carry them.
Old May 1, 2007 | 07:51 PM
TYSON1997's Avatar
TYSON1997
If your doing it I would just call summit thats where I always get my gears from.
Old May 1, 2007 | 10:15 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Are you talking about just for the ring and pinion? I was going to do a GP about a month ago but only two people were interested.
Old May 2, 2007 | 12:39 PM
vettegator005
Id be in if you did it again.
Old May 2, 2007 | 12:44 PM
NOT2MELO's Avatar
NOT2MELO
What is most cost effective, are you just buying the gears and getting
them swapped in and set, or the whole rear swap?
I have had some bad experiences with the backlash and ending up with
worn rear gears because of improper installation.
Might be in for a GP if someone can set it up, looking for 3.90 or 4.10's
myself, whatever is better for daily highway driver.
Old May 2, 2007 | 12:48 PM
Cajundude's Avatar
Cajundude
I'm working on getting a couple of cores right now so I can offer an exchange program as well as installations in June. With the GP you can purchase just the ring and pinion if you wish. I'll look into the gears again and try to set something up again.
Old May 2, 2007 | 12:56 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
^ Im looking at getting just the ring and pinion also and I wanted a hardened output shaft. Do you install them ?
Old May 2, 2007 | 01:06 PM
Cajundude's Avatar
Cajundude
Yes, on the install. I think I'm about to run a special for gear installs at $1050 installed. Left shaft would be an additional $260 (I have them on special right now). May is already full up on me right now so I can't do any installs until June after I get back from Cruise In so the special will be then.
Old May 2, 2007 | 03:02 PM
Corvette-Chris
St. Jude Donor '08
I can get the rear end out easily but I have just never installed ring and pinions so is that the price for you to install the ring and pinion w/ hardened shaft if I send you the rear ?? Thanks
Old May 2, 2007 | 03:17 PM
Cajundude's Avatar
Cajundude
If you were to send me your diff today here is the breakdown on what I would charge you at an everyday rate:
Gear Setting labor - $350.00
Hardened shaft - $260.00
Gears - $375.00
Shipping back - $70.00
Total - $1055.00
If I were to have enough people for a GP on the gears I could get the cost down.
Jason
Old May 2, 2007 | 04:03 PM
Corvette-Chris
St. Jude Donor '08
Cool...Ill let ya know when I get ready to do it
Old May 2, 2007 | 07:33 PM
vettegator005
hey black beauty let me know as well because im in for a hardened shaft and gears as well.
Old May 2, 2007 | 11:59 PM
Corvette-Chris
St. Jude Donor '08
To Best Price for gears.
