it's falling apart.
Old May 2, 2007 | 11:32 AM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
Default it's falling apart.
Engine squeaks... new belts, and neither idler pully is squeaking
Remote keeps losing "lock" even with new battery
Driver's door won't unlock with the remote
Passenger side window won't go down... relay clicks but won't move
And now it sounds like the bearings in my a/c blower are failing, I hope it lasts at least two more weeks, gotta drive 2500 miles to Washington
Old May 2, 2007 | 11:37 AM
OMG's Avatar
OMG
That sucks man and kinda odd.
I thave the Engine squeak problem too. New belts but still squeaked after being on for about two weeks.
My passenger door won't unlock electronically.
Old May 2, 2007 | 11:57 AM
beav626's Avatar
beav626
Good Luck
Old May 2, 2007 | 12:19 PM
When it rains, it pours. Hope things work out with the car.
Old May 2, 2007 | 01:12 PM
max'svette's Avatar
max'svette
St. Jude Donor '11
That is not even close to falling apart. If you blew some headgaskets, lost a driveshaft and the rear diff. As well as a few electrical shorts, that would be "falling apart".
Old May 2, 2007 | 01:25 PM
R Devil's Avatar
R Devil
Minor stuff. You'll be fine.
Old May 2, 2007 | 01:30 PM
tellefan's Avatar
tellefan
That sucks, take it out in a field and shoot it. David
Old May 2, 2007 | 01:51 PM
jrose7004's Avatar
jrose7004
Better drive the Tundra!
Old May 2, 2007 | 02:08 PM
rcs128's Avatar
rcs128
It's an 8-year old car. Things happen, parts wear out. And those thingsy need to be addressed, fixed, or replaced. And when those things are done right all is good.
Old May 2, 2007 | 02:51 PM
GOZ2FST's Avatar
GOZ2FST
Get her fixed up.
Old May 2, 2007 | 03:21 PM
slappy3347's Avatar
slappy3347
I had the same problem. Took it to the dealer. They said there was some sort of ground in the wiring. The tech had the door panel off and all up in the dash. They said it was a common problem but not bad enough to do a recall. They fixed it and it works fine now. Hope you have good luck with yours.
Old May 2, 2007 | 03:38 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Old May 2, 2007 | 04:20 PM
istsme98's Avatar
istsme98
Originally Posted by mph1972
Old May 2, 2007 | 05:51 PM
Ducman69's Avatar
Ducman69
Turn on the engine and just let it idle in neutral. Hold down the switch for the window to go down, and hit the door panel hard with your fist just to the right of the speaker mesh. Remember to use your passenger window every once in a while. I'd recommend a window valet, can pick one up used on the forum inexpensively. I lower both windows to get out of the car and let the valet raise them when locking the doors and lower them again when unlocking. Makes getting in and out of the car easier and ensures your windows won't get stuck from non-use.
Old May 2, 2007 | 05:57 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
THREE VWs FOR UNDER SEVENTEEN THOUSAND!!!!!!
Old May 2, 2007 | 06:09 PM
max'svette's Avatar
max'svette
St. Jude Donor '11
Three V-Dubs yo !!!
Old May 3, 2007 | 01:43 PM
OMG's Avatar
OMG
Hmm...I've taken off the door panel once. I can do it again. Do you knwo where the grounding problem is?
To it's falling apart.
