I've noticed that my right front tire is showing a lot wear on the inside edge. The other tires look fine... The car doesn't pull to the side while driving but does seem to have a noticable rhythmic vibration at highway speeds.
Could the balance be off or does this sound like an alignment problem?
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
A balance problem won't cause what you're seeing - that is most definitely an alignment issue.
My recommendation is to take your car to a shop that is experienced with Corvettes and have them perform a FOUR-wheel alignment, and then take your car to a place that will perform a road force balance (even better if the same shop can do both things).
