Need Help
May 4, 2007 | 08:51 PM
Need Help
just went to kumho nrf tires, want is the correct tire pressure
245/45/17 F 275/45/18 R
May 4, 2007 | 09:04 PM
CI 6-7-8-9 Veteran
St. Jude Donor '07
For everyday 30-36 depending on what they heat up to while driving.
If your driving hard or in rain keep them firmer. If you want a softer ride lower and not push the corners try 28-32. You'll find it by starting out hard and bleeding some out when cold.
May 5, 2007 | 01:15 AM
May 5, 2007 | 01:19 AM
Quote:
Originally Posted by
rws.1
30 psi cold.
May 5, 2007 | 01:21 AM
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
c5joey
Whatever brand you choose, Non Run Flats are a great improvment!
May 5, 2007 | 01:49 AM
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Cozmo
May 5, 2007 | 06:11 AM
St. Jude Donor '08-'09-'10-'11-'12
rws.1
30 psi cold.
May 5, 2007 | 08:59 AM
