Sputters and backfires
Old May 5, 2007 | 07:08 PM
zleehw's Avatar
zleehw
Default Sputters and backfires
When I get on my throttle to pass a car...or take off fast on the on ramp.
I am gettin a preignitionor sputterwhen under heavy load.
Pretty recent tune up and no codes or check engine lights.
It loads up when passin but if I let off pedal just a bit it stops and drives just fine....
Any ideas let me know
Old May 5, 2007 | 07:15 PM
DefenderC5's Avatar
DefenderC5
What did your recent tune up consist of?
Old May 5, 2007 | 08:07 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Old May 6, 2007 | 10:14 AM
zleehw's Avatar
zleehw
Default tune up
brand new engine
-plugs
-wires
-new coils packs
-oil
-filter
the sputtering was minor but recently it is gettin worse.
If I am in a low gearwith medium to high rpms comin to a light and then I get on it to get ahead of traffic and merge over that is when it sputters the most
Old May 6, 2007 | 10:27 AM
M6 Vetter's Avatar
M6 Vetter
Can't help you but bet someone can
Old May 6, 2007 | 10:28 AM
torchvette10's Avatar
torchvette10
Originally Posted by zleehw
brand new engine
-plugs
-wires
-new coils packs
-oil
-filter
Hi there,
please read this thread:
http://www.hptuners.com/forum/showthread.php?t=11884
Are you having the same kind of symptoms? This has been my probem for the last 6 months, it's driving me fking nuts! I am pissed! I changed so many parts already, it is just crazy. The car runs pretty load but when it is under load, it backfires and runs like crap, and if I release the gas pedal just a little bit, it keeps accelerating fine. When you read the thread, look at what has been checked and if you did not do it yet, d it, who knows your issue might be in my list.
I was told to check the MAP sesor (behind the intake) as it regulates LOAD, but it works fine.
Tomorrow I am schedule to have a LS2 ported TB/Intake combo as I have been told that a faulty TB might be causing this.
We have to join our forces They are other members having similar issues (Muncie21, Dope, you and myself) and it's been for several months, no one could resolve it yet.
Please keep us posted and if you have anything to add that could hemp me as well, let me know.
Old May 6, 2007 | 12:30 PM
torchvette10
This thread should be in the C5 tech section. I am sure it would get more views! If the mods could move it it would be great.
Old May 6, 2007 | 01:05 PM
filmelf's Avatar
filmelf
St. Jude Donor '06-'08
Simular problem had to have the throttle body cleaned and a new PCM.
Hope that isn't your situation a new PCM (the main computer) is $1,100.00.
Old May 6, 2007 | 02:34 PM
torchvette10
Thanks Filmef!
I hope the TB will be the issue. As for the PCM, they are sources were we can get it for a few hundred bucks!
If anyone needs a PCM, contact Gene at gmpartshouse.com
for zleehw
Old May 6, 2007 | 02:37 PM
torchvette10
http://www.trademotion.com/partlocat...model=Corvette
PCM for $159, this is the link to the price on www.gmpartshouse.com
Old May 6, 2007 | 07:16 PM
torchvette10
Any news?
Old May 6, 2007 | 07:22 PM
Mr. Azrael's Avatar
Mr. Azrael
Have you checked to see if your plug wires are fully seated on the coils/plugs?
I was having a high RPM/under load misfire that did not activate the MIL, and it was a plug wire partially off a coil pack. Clicking it on cured the problem. We actually caught it on the dyno...
This would happen when trying to accelerate in 6th gear or if I down shifted and goosed it in third/or fourth. Almost thought my expensive clutch was slipping...
I have seen similar results on the F-Body LS1s with a loose plug wire. Might just be the cheapest/easiest solution; at least I hope it is!
Good luck!
Old May 7, 2007 | 05:34 PM
DefenderC5's Avatar
DefenderC5
That was my first thought as well. If they aren't stock plugs, I'd also check to make sure the gap is correct.
To Sputters and backfires
