[Z06] Had an encounter with a Misu Eclipse
Old Oct 19, 2001 | 10:28 PM
Silver Z06's Avatar
Silver Z06
Default Had an encounter with a Misu Eclipse
Tonight I went up to the Texaco to adjust the air pressure in my tires. On the way out I get on it a little and when I hit second the back end came around unexpectedly.
The strange thing was that no matter how much I corrected and braked I couldn't stop the car. I actually went around backwards (360) and ended up sliding into a ditch :cry
As soon as I opened the door a woman came up, asked me if I was OK and wanted to know if I saw the oil in the road. :confused:
So I get out and the car doesnt look that bad. The cops come and block off traffic while this woman is trying to overt traffic from hitting this oil spill.
It turns out that the Eclipse blew something and dropped all his oil in the street which explains the loss of control and inability to recover.
After 2 hours I finally get the car out and it looks like the only damage is to one of the exhaust tips which is bent downwards.
So, my question is, how easy is it to bend the tip back up into normal position on a Ti exhaust? It is only bent about 20 degrees down from normal.
BTW, no one was hurt :)
Old Oct 19, 2001 | 10:46 PM
VetterMan's Avatar
VetterMan
Default Re: Had an encounter with a Misu Eclipse (Silver Z06)
Ouch ... glad your ride didn't suffer more serious damage!:yesnod: Btw, did you have traction control on?
:cheers:
VetterMan
Old Oct 19, 2001 | 10:50 PM
NetJunkie's Avatar
NetJunkie
Default Re: Had an encounter with a Misu Eclipse (VetterMan)
Active handling won't help on oil. I hit gravel once pulling out to a 4 lane road and did a complete 270. It didn't help me...
Old Oct 20, 2001 | 01:02 AM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Had an encounter with a Misu Eclipse (NetJunkie)
:eek: Glad you're OK :yesnod:
Old Oct 20, 2001 | 01:11 AM
jrd's Avatar
jrd
Hey Silver, glad your OK... I hear that the exhaust can be bent using heat but the muffler will have to be removed to do it... Be careful out there...
jrd :eek:
Old Oct 20, 2001 | 01:45 AM
wsaracen's Avatar
wsaracen
glad to hear you are ok. if you cant get it fixed you could get a set of used titanium mufflers from the parts section or it could give you a reason to buy aftermarket???
Old Oct 20, 2001 | 03:30 AM
Silver Z06's Avatar
Silver Z06
Default Re: Had an encounter with a Misu Eclipse (wsaracen)
Thanks guys!
Yes, AH was on. But like Net Junkie said, it didn't help at all. It was really unnerving how out of control I was and how long it took me to stop.
Another lesson learned! :yesnod:
Old Oct 20, 2001 | 09:56 PM
2ndVette's Avatar
2ndVette
what happened with the encounter with the Eclipse? :smash:
Old Oct 20, 2001 | 10:20 PM
Silver Z06's Avatar
Silver Z06
Default Re: Had an encounter with a Misu Eclipse (2ndVette)
Unfortunately, the entire encounter was him spilling oil on the road causing me to wreck.
However, in a race I would have stomped his butt :smash:
[Modified by Silver Z06, 9:21 PM 10/20/2001]
Old Oct 21, 2001 | 01:41 AM
95autoLT1's Avatar
95autoLT1
:eek: That sux. Glad your ok though :)
To Had an encounter with a Misu Eclipse
