Tunnel Plate @ eliteengineeringusa.com
Which one? 1/4, 3/8? Aluminum vs. stainless? Thermal?
Im thinking the Stainless with thermal, but the thicker aluminun worth it over the stainless? Did anyone do this? Could you still thermal over it?
Im getting ready to do my exhaust and its stupid not to do this at the same time.
http://www.eliteengineeringusa.com/C...tes_Order.html
Aluminum KSI is between 40 and 42 PSI and does not change much between 1/8th of an inch and 3/8 and inch.
Stainless Steel has a KSI of 60 to 68 PSI, depending on the metals composition.
Peace
Chip
"This plate offers the most chassis stiffening of any of our products"
ANd it costs $41 more than the stainless.. weird huh?
Reason: There are two large holes
pre-drilled in the tunnel plate (see pic below) for what I believe allows the installer the ability to pass the O2 sensors through for certain custom exhaust installations.For some reason I didn't pay close enough attention to the website photo showing the plate with the holes so I was surprised when I found it delivered that way.
I think CCA should offer the plate with or without the holes as it seems logical the holes will allow more heat to accumulate above the tunnel plate than if there were no holes. This is just my opinion of course.
On the other hand, with the ceramic coating on the plate and the holes, it still might reduce heat more than the stock plate but maybe not as much as it could.
Did I say the plate DOES stiffen the frame? That is definitely noticable.
..rickko..
You would not believe me if I told you the difference in shipping costs between a sheet of 3/16 and 1/4
BTW, as stated above, the cost of aluminum has sky rocketed in the last 6 months...
Peace
Chip
Peace
Chip
