C5 dash help
Old May 6, 2007 | 12:23 PM
G8r3591's Avatar
G8r3591
4th Gear
Default C5 dash help
I'm having difficulty getting the center pod cover to align properly with the dash. I've looked around and I see the same problem I'm having on a number of cars.
Any advise?
Old May 6, 2007 | 12:26 PM
Y2KVert's Avatar
Y2KVert
St. Jude Donor 06
Any advise?
Same problem here. Just chalk it up to the fact that it's a GM product.
Old May 7, 2007 | 04:42 AM
97vetteman's Avatar
97vetteman
They must all be like it, mine doesn't fit that well either!
Old May 7, 2007 | 05:25 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Old May 7, 2007 | 11:26 AM
mneblett's Avatar
mneblett
Any advise?
Very common. I brought the right/top corner closer to the dash by adding some thickness to the panel's right top tab.
This tab was apparently intended to "pull" the panel toward the dash, as it has a beveled top surface that engages the back side of the top edge of the dash opening. Unfortunately, it looks like the panel mold dimensions are "off," as there's not enough engagement with the dash. I glued/zip-tied a few additional layers of thin cardboard to the tab, effectively making the top surface of the tab "thicker." This increased the engagement of the tab with the edge of the dash, i.e., makes the tab contact the dash top edge before the panel can back away from the dash far enough to open up the gap on the right side.
To C5 dash help
