[Z06] 2003 Z06 shifter
Old May 6, 2007 | 01:12 PM
kemboz06's Avatar
kemboz06
Cruising
Default 2003 Z06 shifter
I just bought this Z06 and the shift **** seems to be loose. I accidently pulled on it, and the whole **** and an extension to the **** pulled right off from the actual shifter itself. For some reason this shift **** and the extension doesn't want to screw on tight? do you guys just super glue it back on?
Old May 6, 2007 | 05:11 PM
zo6ken's Avatar
zo6ken
Sounds like someone put an aftermarket **** on your shifter. Or maybe someone changed the shifter also.
Old May 6, 2007 | 05:26 PM
hotwheels57's Avatar
hotwheels57
Is it possible it's not a screw on ****, but one using a small allen head socket set screw on the "extension" below the ****?
To 2003 Z06 shifter
