[Z06] Major Screwup?
Old Oct 20, 2001 | 03:15 PM
01Z06's Avatar
01Z06
Default Major Screwup?
My wife was driving my Z and the low oil level light came on. She took it upon herself to add a quart of oil, but she does'nt know the difference between synthetic and regular oil, so she added a quart of Mobil(at least she got the brand right) 5W-30 regular oil. Is this a major mistake, or is it okay for a few hundred miles until I get a chance to change the entire oil to Mobil 1? A quick reply is needed as she just did this about 30 minutes ago.
Old Oct 20, 2001 | 03:53 PM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
Default Re: Major Screwup? (01Z06)
It won't hurt anything to run it for a few miles. I'd change it as soon as possible though.
[Modified by CorvetteSS, 3:21 PM 10/20/2001]
Old Oct 20, 2001 | 04:18 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
I would change it. To be on the safe side. I also would get your car checked for oil cosuption. Next time to take the cap inside with her and tell show them what oil she needs
Old Oct 20, 2001 | 06:02 PM
Mechanic's Avatar
Mechanic
I hestitate to post any response because the oil police are gonna raise hell with me, but here goes: Mobil 1 is completely compatible with conventional motor oil -- any brand, any weight. The principle reason that reason Corvettes (and Porsches, Mercedes, etc.,) run synthetic oils is because sythethics can withstand almost twice the temperature extremes of conventional motor oil and still provide the protection required to prevent wear, scuffing, etc. As heat became more of a problem, manufacturers opted for synthetic oils rather than add oil coolers. It's not much more complex than that. By adding a quart of conventional oil to a 6.5 - 7 quart sump, you "lost" something on the order of 12-15% of Mobil 1's capacity to absorb extremes of heat and cold. I, too, would change the oil, but I wouldn't worry about doing so until it was convenient.
Old Oct 20, 2001 | 07:33 PM
HummelS's Avatar
HummelS
Default Re: Major Screwup? (Mechanic)
Some Forum members have reported using conventional oil improves the oil consumption problem with the Z. I wouldn't worry about it either.
Old Oct 20, 2001 | 08:19 PM
DownEaster's Avatar
DownEaster
Mechanic,
Good response, thats the kind of info one hopes for when he/she posts a problem.
Old Oct 20, 2001 | 08:30 PM
kh24's Avatar
kh24
I dont think it would cause a problem. The owners manual states that if you are low on oil and synthetic isnt available you could use a quart of conventional motor oil to get you back up to the full line. I would fill it to capacity with Mobil 1 but not be worried about getting the oil changed any sooner.
Old Oct 20, 2001 | 09:22 PM
SWCDuke's Avatar
SWCDuke
This is the "Oil Police", Mechanic. You're dead on correct.
Mixing a quart of mineral oil with synthetic is no big deal and isn't going to cause any harm. What do you think all those semi-synthetic blends are?
Just change the oil at your normal interval based on the DIC oil monitor, mileage, time, or whatever algorithm you use.
Duke
Old Oct 21, 2001 | 12:11 AM
Mervz's Avatar
Mervz
Cruise-In V Veteran
Cruise-In VI Veteran
whatever you do, don't tell your service manager.
Thats grounds for(and yes its stupid), voiding your engine warrenty. :(
Old Oct 22, 2001 | 11:00 AM
jerryv's Avatar
jerryv
Default Re: Major Screwup? (Mervz)
I'm with Mechanic. No big deal. Change it when it's convenient for you.
Old Oct 25, 2001 | 01:12 PM
Mark S.'s Avatar
Mark S.
Good reason to not let your wife drive your Vette anymore. :lol:
I am purist...I would get it changed reasonably soon and when it's convenient for you.
Old Oct 25, 2001 | 02:47 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: Major Screwup? (Mark S.)
I also don't think its that big of a deal. At least she didn't just keep on driving. I know some people who have done that.
Old Oct 28, 2001 | 02:20 AM
silversport's Avatar
silversport
Default Re: Major Screwup? (rschiltz)
I'm with rschiltz...most would have ran it dry...buy her a nice dinner...it WILL win you points...unless she reads this Forum!!! :D :jester :lol: :chevy
Old Oct 28, 2001 | 02:48 AM
corvette dave's Avatar
corvette dave
Your wife did the right thing.
I would not change it until the next oil change is due.
The non-synthetic oil will not hurt a thing.
You know that 6 1/2 quarts that go in the Z06.
Mine only has 6 quarts of Mobil 1 synthetic. Don't tell anyone. :lol:
Old Oct 28, 2001 | 03:06 AM
Joecooool's Avatar
Joecooool
Jax Events Coordinator
CI 3-4-5-6-7-8-9 Veteran
St. Jude Donor '03-'08
The oil issue and opinions that come up on the subject just amaze me.
Did you know that the majority of LS1's on the road today are running regular oil in them? Thats what GM puts in every single Z28, V8 Firebird, Trans Am and that 4 door car they sell down under. The only cars getting the Mobile 1 are the Vettes. Camaro SS & and the Firebird WS6.
Personally, I think they do it because of the marketing agreement with Mobile - not any performance improvement. Ever notice that Mobile 1 uses the Vette in its commercials? I also think that the Mobile 1 is the source of the problem for those Vettes that are burning oil. Mobile 1 is so slick, it doesn't allow the rings to set the way they should.
I'm running 10 W 30 in my Z06, I have had zero perfromance degradation and with 4000 miles, I only cooked off a little less than a quart. Thats probably due to my many visits to the local drag strip, not bad rings.
Just my $.02
Old Oct 29, 2001 | 12:23 AM
PAGJA's Avatar
PAGJA
wow...WHAT A WIFE!!! For her to even know where to lift the hood, locate the proper fill area...is amazing!!! She is either a car buff herself or has seen you under-the-hood a few times... kudos to her!!!! :cheers:
Old Oct 29, 2001 | 12:46 PM
dbvettez06's Avatar
dbvettez06
Default Re: Major Screwup? (PAGJA)
Hey keep her shes ok...I heard a story about a woman in Toronto who added a quart of oil to the gas tank...When the gas station attendant asked her why she was putting oil in the gas tank, she said "It all goes to the motor, right?"
:lol: :lol: :lol: :lol:
To Major Screwup?
Old Oct 29, 2001 | 12:59 PM
Mark S.'s Avatar
Mark S.
Default Re: Major Screwup? (corvette dave)
Corvette Dave, haven't you heard that '01s and '02s take 7 qts to reach the MAX line on their dipsticks (as opposed to the 97 thru 00 models which only require 6.5 qts)?
At least that's what the posters on the forum believe when polled. ;)
[Modified by Mark S., 10:59 AM 10/29/2001]
[Modified by Mark S., 11:00 AM 10/29/2001]
Old Oct 29, 2001 | 01:52 PM
gmblack3's Avatar
gmblack3
My 01 ZO6 took 7 qts to the full line. I did raise the rear end higher than the front when I drained the oil. I think if you raise the rearend higher then the front you will need 7 qts to fill it to the full line. If you do a level drain 6.5qts will fill it to the full line. JMO
Old Oct 30, 2001 | 12:28 AM
corvette dave
Mark,
Yes I have been following the posts on oil. I actually put in 6 3/4 quarts to reach full. 6 1/2 just sounded better.
Guess we got off topic a little.
