Uneven idle
Old May 9, 2007 | 07:15 AM
Dudule's Avatar
Dudule
Default Uneven idle
I guys,
I've tried a 2001 C5 yesterday, the car is very nice, clean and meets all my expectation regarding the C5 that I'm looking for.
The only annoying stuff about this car is the uneven idle. It fells like the engine misfires at idle, it's not shon on the RPM gauge but you can feel it, and the owner told me that the spark plugs need to be changed (which he's gonna do before I'd buy the car), the car has 42000 miles.
Do you ever experienced the same and what do you think?
Thanks for your info
Greg
Old May 9, 2007 | 07:48 AM
VinnyT's Avatar
VinnyT
You will hear many answers to this. Plugs are good to 75000+ miles, but changing them wouldn't hurt. The LS1 motors will have the idle shudder to it. Many here will chime in with that. Drive it with the windows up, no radio and a smooth road if possible(a hill would be best). If it is misfiring you'll feel it. I think it is the notorious shudder. Nothing to worry about.
Old May 9, 2007 | 09:59 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
I notcie it more after the engine warms up, but there is a slight roughness to the idle...
Old May 9, 2007 | 10:09 AM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Let them change the plugs and test drive it again.
Did you notice if there is any rhythm to the "roughness"? It is possible there is a small cam in there.
Old May 9, 2007 | 11:37 AM
Dudule's Avatar
Dudule
That's true the engine ran roughly when warm (after the test drive) and I didn't notice any rythm in the roughless (but I'm not a musician )...
Old May 9, 2007 | 11:42 AM
Humy's Avatar
Humy
oh yeah, mine idles rough, it because the engine run lean or something like that
- and if the car is misfiring you will get a warning on your DIC
Old May 9, 2007 | 11:51 AM
Jistari's Avatar
Jistari
Ok, check one problem off the list
I just noticed this yesterday, a very small roughness when ideling. Didn't remember it being there before. Drives/performs fine.
Didn't know this was common with the LS1.
Old May 9, 2007 | 11:55 AM
VinnyT's Avatar
VinnyT
Rough idle is normal. My old 98 Z28 had the same thing.
Old May 9, 2007 | 12:20 PM
max'svette's Avatar
max'svette
St. Jude Donor '11
These engines idle a bit rough... by that I mean you can feel the engine runing as opposed to most other modern cars. I asked the same question when I first joined. I chalked it up to "they all do that".
If your idle is jumping up and down and there are noises that are not supposed to be there you have other problems at hand.
Old May 9, 2007 | 12:34 PM
RogerT's Avatar
RogerT
Default Solution ?
I read in one of the well known C5 modification books about using spray throttle body cleaner periodicly to solve this very problem. I hope this helps.
Roger T
Old May 9, 2007 | 12:40 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Did someone upgrade from the stock cam? Even a mild performance cam will change the idling characteristics of an engine.
To Uneven idle
