Acetone in Gas?
Old May 9, 2007 | 11:41 AM
reactor2's Avatar
reactor2
Default Acetone in Gas?
Has anyone tried this? The widespread claim is that you can boost your fuel economy by 3-4 gallons by adding about 2 ounces of pure acetone to 10 gallons of fuel.
Old May 9, 2007 | 11:43 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
try it and report back.
Maybe add the hurricane also
Old May 9, 2007 | 11:46 AM
rws.1's Avatar
rws.1
read this
http://neubranderinc.com/blog/2007/0...soline-busted/
Old May 9, 2007 | 11:47 AM
corvette-pilot's Avatar
corvette-pilot
I'd rather put on more stickers to get increased power, screw the mileage
Old May 9, 2007 | 11:51 AM
reactor2's Avatar
reactor2
I'm tempted to try the acetone, but I'd much rather someone tried it before me
The Hurricane... I think in certain intakes that thing just might work.
Old May 9, 2007 | 11:52 AM
reactor2's Avatar
reactor2
Remember to increase mileage this way you would have to be making more power
Old May 9, 2007 | 12:48 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Yes, I have tried it several times and it does work.
I won't bother trying it in my Z06, what's the point, however I tested it in my 1999 Dodge Dakota 4X4.
I add about 3 ounces of acetone to 10 gallons of gas. My average fuel economy is 14-15 mpg around town and after adding acetone it bumps up to 17-18 mpg.
Try reading these,
http://www.lubedev.com/smartgas/additive.htm
http://pesn.com/2005/03/17/6900069_Acetone/
http://peswiki.com/index.php/Directo..._Fuel_Additive
Old May 9, 2007 | 01:09 PM
Illini82's Avatar
Illini82
St. Jude Donor '07
Be careful, remember acetone likes to feed on rubber
Old May 9, 2007 | 02:03 PM
Herringchoker's Avatar
Herringchoker
From: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
Try some "Berrymans B12" fuel add. it has the proper amount, it will dissolve styrine build-up on your injectors.
Old May 9, 2007 | 02:09 PM
max'svette's Avatar
max'svette
St. Jude Donor '11
I already got those magnets that "atomize the fuel"
I already got the tornado
and now I have to use Acetone... screw this my gas mileage already went up 200% with the above mentioned modifications, i don't need anything better. hahahahahahahahaha
Old May 9, 2007 | 02:42 PM
jrizzuto's Avatar
jrizzuto
really interesting stuff. with all that research, how can they be wrong?
But I do agree with the warning about rubber - and don't forget we have rubber seals between our 2 tanks. Mine leaked and had to replace the entire tank assembly - the dealer said is is easier to replace the whole tank rather than replace the o-rings in the connecter tube. I was under warrantee, so I could care less.
I can't prove it, but I think I know how it happened. I added a can of Seafoam to a half-full tank a week prior to the leak. The next day I got a fill-up....but the damage may have already been done. Now I learned to never add anything to the tank without washing it down immediately with a fill-up.
Old May 9, 2007 | 02:46 PM
Benpup's Avatar
Benpup
I wouldn't I used some acetone to clean out a plastic airbrush bottle and found a mess of melted plastic on the floor that used to be the bottle.
I do know a retired automotive engineer (Won't tell you what company but the initials are General Motors) that puts 3 ounces of kerosene in his 03 Vette every other tank fill and gets 35 constantly on the road.
I don't really know what it does, but I wouldn't do it.
To Acetone in Gas?
