Just wondering what affects have been noticed by adding aftermarket underdrive pulleys to a Z06. Ayone have any feelings? I don't plan on many mods, hurricane intake, eventually LG Pro LT headers and high flow cats. Are pulleys good to do with a tune or is the money better spent elsewhere? Also am curious about adverse affects (AC won't work well at idle, drains battery, etc.)? Thanks!
Reason: spelling
It's one of those "if you are already in there" jobs, do it. But don't tear the rack and front of the motor out JUST to do the pulley.
I put an SLP on my 01 (while in there fixing an oil leak). AC side of the pulley is same as stock, so no compressor reduction speed there. I get full volt at idle (stock rpm idle) and no cooling issues.
Whatever pulley you get, get one with a 3/16 keyway and pin it on the crank while you are in there.
So basically, unless you do the cam, really not worth the effort. I'll admit, I doubt I would do it myself anyway, but I doubt its worth $300 in labor to get it done for me.
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I had an ASP underdrive pulley recently installed when I had my head and cam install done. I have definitely noticed a difference in that if I try to start my car with the AC on, it will die. Even when I've been driving for awhile and then come to a stop sign (with AC on) the RPMs will drop really low like it's going to die, but then kick back up at the last minute. I still have the stock battery so that might be part of the issue, I plan on getting it replaced next week.
Get it tuned. It's not your underdrive pulley. Mine did the same thing.
