Help!!! Crickets in my Engine... Chirp Chirp!!!
I remember a member, maybe Scissors, suggested some type of grease to silence it once and for all. Anybody remember, or have any other tips???
I've got a trip to Destin Florida next week, and I don't want the chirping for 14+ hours.
Thanks!
http://forums.corvetteforum.com/show....php?t=1411923
BTW, noise went away before I had a chance to do anything.
1. remove the top serpentine belt
2. remove the lower A/C belt
3. hand spin each pulley. they should move freely without wobble. If one of then binds, wobbles or feels gritty that is the culprit.
IF that does not identify the problem, leave the lower belt off and install the upper belt.
If there is a squeal it is on th eupper system. If there is not squeal the problem is on the lower system.
... but she looks real good parked !
Picked them up from AutoZone Friday night, and put them on Saturday morning. Had a bit of a time with the socket on the lower side, but finally, SUCCESS!!!
No more crickets!!
Thanks again, guys!
Get your car looked at before you get stranded.
Good luck.
... but she looks real good parked !Now the dealer installs these parts but then screwed up my power steering pump trying to remove that $110 part. So I had to get a new power steering pump. $280 ,,, they get their $$$ anyway they can. Anyways everything is installed all is quiet I'm as happy as can be.
Next day I'm washing my car and notice OIL under the car
,,, the friggen steering pump is leaking fluid . Took her back to the dealer,, they changed the pump.. now there's no leak but there's a squeek again... W T F !!! So far I've spent about $1300 on this problem and it's still not resolved. I'm supposed to go back.. but they are as fed up as I am..
Think this little girl will be for sale soon !
I hate to hear that, because most of the time a chirp is belt related, I followed rws.1 steps and found both pulleys on the AC belt were shot tensioner and pulley. When I removed them I found the grease flung out of the seal only 35K miles, kind of common but I would look into that area. Spent about an hour replacing the pulley, tensioner and belt and as is well, completely quiet.
