tire size question
Old May 11, 2007 | 07:58 AM
2vetteguy's Avatar
2vetteguy
Default tire size question
i would like to know what are the tire sizes that have worked well on a 2000 vert that is lowered on stock thin spoke wheels, i am ready to replace the runflats on mine and would like improve looks and ride
Old May 11, 2007 | 08:45 AM
rws.1's Avatar
rws.1
umless you are changing wheel size ( larger diameter or width) I suggest you stay with stock tire sizes. That will give you the broadest selection of tires in terms of performance and price
You will find that the runlfats because of their square walls have a wider tread width than non run flats.
Many upgrade to Z06 width wheels ( +1 inch fronm and back) and go to Z06 sized tires.
Old May 11, 2007 | 08:57 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
You could increase the front size to a 255-40x17 safely on an 8.5" wide wheel, but the back is about as wide as you can go on a 9.5" wide.
As suggested, if you are considering Z06 sized tires, you need the wheels that are 9.5" wide in front and 10.5" wide in back.
To tire size question
