My temp guage that lets you know the outside temp, is acting up. It was working fine until today. It always says 56 degrees right now the out side temp is 73. Is there a sensor that can be changed or a fuse. Thanks ......
Most likely the sensor is bad or has come disconnected. It is located on the bottom passenger side of the radiator shroud. You can see it from under the front of the car.
