Exhaust question
Old May 13, 2007 | 11:40 AM
RUNNINGMAN 1's Avatar
RUNNINGMAN 1
Default Exhaust question
I have the Borla cat back and love the sound I was wondering if there would be a benefit to going with a aftermarket cross pipe?I apoligize ahead if this is a stupid question
Old May 13, 2007 | 12:01 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Depends on what you mean by benefit.
It will smooth out the sound a little. Some will reduce the "popping" a little.
However there would be very little if any power gain, until you have a H/C and LT's, High Flow Cats, ect...
Peace
Chip
__________________
..................Click for
Old May 13, 2007 | 01:02 PM
RUNNINGMAN 1
Peace
Chip
Thanks when you say smooth do you mean quiet because I like the sound but I wouldn,t mind reducing the popping but will I lose any h.p?
Old May 13, 2007 | 01:04 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
If I may Chime in! You should not loose any HP but gain a smoother sound in that combo!
Now as stated above your greatest benefit will be if you go with LG Tubes Hiflow Cats and the X-Pipe
It will change the sound slightly!
Thanks,Matt
Old May 13, 2007 | 01:07 PM
RUNNINGMAN 1
Old May 13, 2007 | 04:14 PM
Meebix's Avatar
Meebix
An aftermarket X pipe will definitely not make it quieter.... only louder!
Old May 13, 2007 | 06:54 PM
If you are experiencing any popping or resonance, the x-pipe could help with that.
Old May 13, 2007 | 06:58 PM
JWB ZO6's Avatar
JWB ZO6
St. Jude Donor '06-'07
Thanks,Matt
Old May 13, 2007 | 08:48 PM
Paulg680's Avatar
Paulg680
CI 7-8-9 & 12 Veteran
Wounded Warrior Escort '11
I started with a stock exhaust and added the twin pipe Borla Stingers. A few months later I added a Bassanni X-pipe. To be honest it didn't make much difference at all. The sound was somewhat smoother at higher RPMs, but that's about it. If you want to make a significant change in sound, add a beefier cam and LT headers.
To Exhaust question
