Ac Not Blowing Cold
Old May 13, 2007 | 11:53 PM
Ishams00vette's Avatar
Ishams00vette
Default Ac Not Blowing Cold
What are some of the solutions? MY a/c is not blowing cold at all anymore. Could it just be low on free on? Line messed up? Compressor seems to be working properly.
Old May 13, 2007 | 11:55 PM
nickolbag's Avatar
nickolbag
Check freon and pull codes first.
Old May 14, 2007 | 06:08 AM
INaband's Avatar
INaband
CI 7-8 Veteran
Probably need to add some R134a....I did..
Old May 14, 2007 | 07:20 AM
BostonJoel's Avatar
BostonJoel
Worth checking the control module in the dash.
Old May 14, 2007 | 07:59 AM
Vette_Fan's Avatar
Vette_Fan
I bought that can with R134a. I can't seem to understand the instuctions. Where do I need to attach it. Where's the input located? I think a lot of guys would wana do this during summer..
Old May 14, 2007 | 08:07 AM
mcintex's Avatar
mcintex
St. Jude Donor '06-'07
It is closest to the passenger side fender and door. The fitting on the kit will only fit the low side.
Old May 14, 2007 | 10:03 AM
nickolbag's Avatar
nickolbag
How can you diagnosis that this module is the problem? Is there a write up on how to get to it? Reason I ask is I think I may need to replace mine.
Old May 14, 2007 | 11:11 AM
jrose7004's Avatar
jrose7004
I'll bet that you need to charge it. You probably have a leak that needs repair.
Old May 14, 2007 | 01:47 PM
Ishams00vette
Are parts for leak fixes pretty expensive??
Old May 14, 2007 | 02:01 PM
kingsey's Avatar
kingsey
Id like to know as well because mines blowing room temp. air as well
Old May 14, 2007 | 05:59 PM
T VETTE's Avatar
T VETTE
It could be a few different things. If you need to add freon you likely have a leak. It will not go away. It seems one can will last a few months, it is good. DON'T OVERFILL. Then you add another can in one month, good again. On and on. Get a pro to sniff out the leak, many times it is a compressor leak. If the compressor is actually on with the clutch engauged and blowing warm it could be a relay or fuse as the compressor will usually shut down or cycle rapidly when low on freon. If a compressor you can get a rebuilt or new, could be a few hundred rebuilt, new at the stealership is $760 plus labor and with a recharge of R 134a added on. If you don't know don't guess, it costs more to replace wrong parts.
Old May 14, 2007 | 07:33 PM
Ishams00vette
Ok I got our shop foreman to check it out and he said I need two temp acuators. How much are those? Does any one know???
Old May 14, 2007 | 08:27 PM
T VETTE's Avatar
T VETTE
Not sure on that one, call Chevrolet.
To Ac Not Blowing Cold
