[Z06] gaskets? taking things apart
Old May 14, 2007 | 06:32 PM
bill mcdonald's Avatar
bill mcdonald
Default gaskets? taking things apart
I need to remove the intake to replace the oil sender, will I need to buy new gaskets?
Also think a noise is comming from the valve train. I would like to remove the valve cover, will I need gaskets here?
Old May 14, 2007 | 06:44 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
All those areas are sealed by O-rings. Unless something is damaged during removal, which would be very rare, there is no need to replace them.
Old May 14, 2007 | 07:00 PM
bill mcdonald
I read on the 01 oil burners the dealer wants to reseal the intake before owning up to the rings being the problem.
any idea what they do?
Old May 15, 2007 | 10:18 AM
Z06ufgrad2002
I claim on that one. I don't see how resealing the intake would have any bearing on whether or not it burns oil. Next they will want to reseal the TB before accepting the fact that the '01's are oil burners and need to be reringed.
Old May 15, 2007 | 01:13 PM
UstaB-GS549's Avatar
UstaB-GS549
Read the TSB. You can see the valley seal leakage information. It's a fairly common with all LS6 engines. A friend has a catch can on 2004 Z06 that will trap a quart of oil in short order. Yes, it's burning oil, but it's not getting past the rings.
http://www.corvetteactioncenter.com/....php?qstId=263
Old May 15, 2007 | 04:14 PM
Z06ufgrad2002
Ok but, the valley cover and the intake manifold are two completely different parts. The post stated that they wanted to reseal the intake not the valley cover. Also the catch can traps oil from a different source. That also does not address the piston rings.
To gaskets? taking things apart
