High pitched squeak
Old May 14, 2007 | 11:37 PM
sdnet's Avatar
sdnet
Default High pitched squeak
Hello all:
I have a Magnuson supercharger installed in my 99, and lately, I've been hearing a high pitched squeak, or a whistle, when I accelerate. No, it's not the whine of the supercharger. This is different. It's tough to explain, but I can only hear the squeak/whistle upon acceleration...if I'm coasting or just maintaining speed, I don't hear it.
Any clue?
Old May 15, 2007 | 11:07 AM
sdnet's Avatar
sdnet
Bump...
Anybody?
Old May 15, 2007 | 12:19 PM
M6 Vetter's Avatar
M6 Vetter
Can't help you, sorry. But someone will chime in
Old May 15, 2007 | 01:16 PM
itchynackers's Avatar
itchynackers
I have it too. It only happens under part throttle around 2100rpm. I believe its the air intake. It actually did it before I had the magnuson on.
Old May 15, 2007 | 01:18 PM
sdnet's Avatar
sdnet
Yeah, mine seems to be part throttle also...although it is tough hearing much of anything but the exhaust when I floor it, or even just accelerate quickly.
The Magnuson supercharger actually comes with its own air intake. So with you, that squeak actually occurred with two separate intakes? That's interesting.
Old May 15, 2007 | 02:03 PM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
Look at the idler pulley or tensioner ...could also be a belt
Old May 15, 2007 | 04:31 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I too have the Maggie, but don't have the squeak. I know that this blower puts hellacious loads on the pulleys. Mine was puking belts every day until I called Magnuson and they told me about an update that keeps the tensioner from deflecting away from the block and throwing the belt off. That worked fine until I ripped the idler pulley off along with the entire corner of the aluminum bracket that it's bolted to. I tig welded the crap out of that and have been fine for 1kmi so far. With all of the load the blower places on the pulleys, I would try to carefully spray some good penetrating lube on the pulleys ( 1 at a time ) to possibly isolate the problem. Spray the idler and go for a drive. If it goes away, there you go. If not, continue to the idler on the maggie, then the tensioner. You may also remove the belt and check for any play in the pulleys. Let us all know what you find.
Old May 15, 2007 | 04:34 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Sounds as if one of the pully's or idler pulley's are in need of a replacement!
Possible to be the A/C idler pulley as is mine or it is also possible for it to be the alternator which will do this under acceleration.
You'll need to get someone to help you identify it!
Thanks,Matt
Old May 15, 2007 | 04:51 PM
sdnet's Avatar
sdnet
Maybe...that surely didn't take long. I haven't even had it installed for a year. Thanks everyone for the suggestions.
Old Jun 2, 2007 | 12:55 PM
sdnet's Avatar
sdnet
Okay, I have an update on this. Coming home from work yesterday, I decided to make sure that the supercharger was still making the boost that it's supposed to. It should be at about 6 and 1/2 lbs. However, even when floor the accelerator, it's only making between 3 and 4 lbs. That means I've lost half of the boost that the charger is supposed to produce. Does that change this scenario at all?
Old Jun 2, 2007 | 02:07 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
I don't know much about Maggies but
1) do you have a blowoff valve? could it be leaking (and whistling)?
2) is it possible your rear drive belt is slipping?
Old Jun 2, 2007 | 02:17 PM
sdnet's Avatar
sdnet
I am at a distinct disadvantage because I'm not very mechanically inclined. I know the basics, but my debugging skills with automobiles definitely needs improvement. I've popped the hood and checked the hoses and they all SEEM to be connected just fine, although that doesn't mean there isn't a crack in one of them that I just can't find.
Where would the blow off valve be?
Old Jun 2, 2007 | 02:19 PM
sdnet's Avatar
sdnet
Actually, according to this Wiki article, the Magnuson would not have a blow off valve, as it is roots and not a centi-type supercharger:
http://en.wikipedia.org/wiki/Blowoff_valve
To High pitched squeak
