dry spot on paint
Old May 17, 2007 | 06:06 PM
chate's Avatar
chate
Default dry spot on paint
I cant get a picture of it, but on my black C5 there is about a 6" by 6" spot on passenger door that looks like its dry, you know the rest of the body looks glossy and highly reflective, and this region has a light foggy haze to it, and it feels unsmooth to the touch too, not rough, just not glossy like the rest of the body. I just noticed it, is there a fix or did the glossy coat get ripped off by too many admiring fans? AHHHH i think im goign to cry...
Old May 17, 2007 | 06:40 PM
max'svette's Avatar
max'svette
St. Jude Donor '11
Sounds like the clear coat is gone. Only way to fix would be to re-shoot that part of the car.
Old May 17, 2007 | 06:42 PM
Might want to see what a body shop would charge to shoot that door.
Old May 17, 2007 | 07:10 PM
chate's Avatar
chate
crapola, sounds expensive
Is there like a jar of clearcoat i can buy and do it myself?
Old May 17, 2007 | 08:17 PM
RedSoxFan's Avatar
RedSoxFan
I don't think I'd try that one myself, get an estimate from a reputable shop, it might not cost as much as you think.
Old May 17, 2007 | 08:31 PM
superjet701k's Avatar
superjet701k
yea use a butter knife to apply
Old May 17, 2007 | 08:33 PM
warpster's Avatar
warpster
Try using clay bar on it....something could have gotten on that spot, clay bar should get it off. A lot cheaper than painting, can't hurt! Good luck!!!
Old May 17, 2007 | 10:59 PM
BanditSRT's Avatar
BanditSRT
Try a reputable detailer before you do anything. They can probably polish it out in no time!
Old May 18, 2007 | 12:43 AM
chate's Avatar
chate
damn. i guess tomo's paycheck will go to tinting, gas and a detailer...
thanks for the info guys!
Old May 18, 2007 | 12:58 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Hit it with an ROB and some IP first...
Peace
Chip
__________________
..................Click for
Old May 18, 2007 | 03:31 AM
2klude's Avatar
2klude
anyone care to explain how something like this could happend?
Old May 18, 2007 | 05:30 AM
Black 'n Tan's Avatar
Black 'n Tan
St. Jude Donor '07
Yes, it sounds like to me a scratch or defect was "blended in". Meaning the body shop fixed the small area, and the clear was poor quality, or not applied properly, and is deteriorating. I would see if it could be compounded out, see if someone with a buffing wheel can compound it out, it just may need to be "rubbed" out. Someone prior who had wet-sanded a scratch and not buffed it out properly would also leave that dullness.
John
Old May 18, 2007 | 09:16 AM
steve8's Avatar
steve8
I'd certainly try to clay and polish the area. A pc would be a big help.
Old May 18, 2007 | 09:43 AM
robert123's Avatar
robert123
If the clearcoat is gone you are out of luck. You will need to respray and clear the door.
Old May 18, 2007 | 09:49 AM
rcs128's Avatar
rcs128
Adam's makes some great paint cleaner/restore stuff (can't think of the actual name at the moment) that fixed some minor dull spots on my car. I'd certainly try a claybar and then the Adam's stuff (using a good buffer) before going for a new clearcoat. It really depends on the severity of the troubled area, of course.
Old May 18, 2007 | 10:25 AM
vpunteney's Avatar
vpunteney
John
I totaly agree with John, a lot of used car lots use a service to take out large scratches. It looks good for a couple of years, but then starts to look bad. They sand out the scratch, fog in the color, then fog on the clear in a small area. They have to thin the clear to get it to set on top of the base clear. After a few years it simply peels off, or gets rough. I have done this my self to a couple of drivers I own, it works well, but you have to do it every few years to keep it looking good. To do it right, you will need to get the entire door sanded and shot.
Vinnie
To dry spot on paint
