dead battery
Old May 18, 2007 | 01:54 PM
cadillacman46's Avatar
cadillacman46
Default dead battery
I have a 2004 with 10,000 kms. It has sat all winter but I have started it a couple of times. Now whenever I get in after it has been sitting a couple of days I have dead battery. I have traced it down to dash lights staying on all the time. Any suggestions?
Thanks,
Don
In trying to turn up the brightness on the HUD I mistakenly turned it on and thanks to a member this solved the proble.
Thanks Guys.
Don
Old May 18, 2007 | 02:02 PM
M6 Vetter's Avatar
M6 Vetter
I would buy a new battery NOW. Not good for the battery to go empty so many times.
EDIT: Buy a battery tender.
Old May 18, 2007 | 02:24 PM
hk940's Avatar
hk940
you have a dead battery. buy a new one. also get a battery tender or disconnect the positive cable when you put it up "for the winter".
Old May 18, 2007 | 02:44 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
I have to ask an obvious question about your lights being on - it is not because the dash light brightness **** is turned to the position that the inside lights stay on is it?
Old May 18, 2007 | 03:22 PM
nickolbag's Avatar
nickolbag
I got a real cheap battery tender at walmart. Keeps my battery charged in the winter.
Old May 18, 2007 | 03:39 PM
WetteVette's Avatar
WetteVette
Problem: Dead Battery
Solution: Get a New One
Prevention: Get a Battery Tender
To dead battery
