hi guys, i bought a 2001 zo6 with 11k miles a couple of months ago, and have since added about 900 miles on it.my question is regarding burning oil, my oil level seems to be full still but the exhaust is always black and wet and the back of the car has black specks all over , even right after i wash it.would this be because of oil burning?
Might be, this was an issue w/ 2001..did the previous owner ever get the rings replaced? Or do you have any other info on the car, such as service history?
i dont think the rings were ever touched, other then using more oil how bad of a problem is it? also the car has some work done to it ,procharger and exhaust etc.
Could be some oil consumption. You have a Procharger....could be an "incorrect" tune. Possibly running rich at certain RPM. Oil smoke is blueish gray. Too much fuel is black smoke.
Black specs = carbon. Not oil. If you cannot measure oil consumption, then it's fuel.
if its fuel then what do i do, procharger was install and tuned by esc before i got it, like two years ago, can a tune become undone or change over time?
I have a 2001 zo6 with an air ram and thats it but mine is running hot and burning oil what temp should the fans be set to come on fan 1 and 2 and what temp is normal for this model, i have a diablo tuner.
