[Z06] Notch second gear with HURST shifter getting old what's good replacment?
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Title says it all. My hurst short throw shifter is decent but pretty notchy going into 2nd gear many times which can get old. What is the best replacement short throw shifter for my 02 Z06 that will solve this problem?
How about the C6 Z06 shifter, will that take care of my issues?
Hammer
When my Hurst seemed like it was "notchy", I took the boot off, and realigned everything, meaning loosening the shifter box bolts and rod locking bolt, and using the centering pin to realign it all. It was off a bit, don't know how cause it was tight, but the shifter worked alot smoother afterwards.
Same here. My Hurst was notchy and hard to get into first at times. I took the boot off, loosened the mounting bolts and carefully aligned and centered the shifter before tightening it back down. Now it's waaaayyyyy smother and I have no problems with first gear.
I'd try adjusting it before replacing the shifter.
I got the C6Z shifter, and love it, but you might try the alignment procedure first. The A-V mod did nothing for me, but when I installed the new C6 shifter, I took care to align the attachment to the cable, and the result is WAY smoother than my old BPP. However, the actual throws are longer than an aftermarket unit. Well worth the trade-off for me, but may not be for others.
St. Jude Donor '08
Jim M
St. Jude Donor '06
Sounds like a game plan gentleman thank you!
1 Post
St. Jude Donor '08
FWIW, it's probably a combination of things causing the notchiness. I have a 99 FRC. We switched to a hurst shifter which was a big improvement over stock but was still difficult to shift. Then we did the anti-venom mod. HUGE improvement!! There is a detente bolt (bolt has a spring loaded ball at the end of it) in the middle of the transmission on the passenger side. What you need to do is go to parts store and by oil pan bolt size washers ( we used 2) and some silicone to prevent leakage. Unscrew bolt, put on washers with silicone and tigthen bolt. Your shifter will now be much easier to use because you have reduced pressure of spring. Should not take more than 20 minutes or so to do.
The hurst shifter I have has 2 sets of springs. I used the stronger springs, going to try the lighter springs and see where that gets me.
hey guys, would it be worth it to do the anti-venom mod with a C6 shifter, or not since the C6 Z06 shifter is closer to stock.
Just wondering because my C6 shifter should be coming in a few days.
1 Post
St. Jude Donor '08
Do it!! I promise you'll thank me.
Here is a thread with more info.
http://forums.corvetteforum.com/show....php?t=1464382
the best analogy for stock shifter with anti-venom that I have heard so far is that it feels like shifting 72 VW bus with no shift gates...
and here is a good thread that details both anti-venom and shifter adjustment: http://forums.corvetteforum.com/show...ght=anti-venom
1 Post
St. Jude Donor '05-'06
Meet me in the middle some place, I drive your FI Z, you drive my HC Z, first round on me, then we try and rember what the problem was
Seriously brother, I bet it is a we bit off center maybe??? I try the no thumb on the 1-2 and it is notchy to me. I wrap my thumb and I nail it
Take car man, and I am trying to be like you and break my HPDE cherry (next month looks like a positive maybe )
Dave
Dave
I say no way for the C6 shifter, it's the same throw as the stock C5 Z06 shifter with a shorter and slightly angled shaft. Unless you install a shifter with a substantially shorter throw (B&M, MTI, Hurst, etc) than stock there is no need for the anti-venom mod...
Thanks for the quick answer jbauch, I was thinking the same thing, and won't do the anti-venom mod with the new shifter upgrade .
you may want to do a search and refresh the old thread, or start a new one. but somebody doing engineering for MTI started a rumor that they were coming out with a new design of the shifter and were going to be replacing the rattler. we never got good details on the swap, or if it actually was going to happen.... I am pretty interested if it does happen cause mine is a rattler too...
