climate control display
Old May 19, 2007 | 02:02 PM
newyorknick's Avatar
newyorknick
Default climate control display
in addition to the temp display being dim now some of the other indicator lites have flamed out....anyone replace this item or repair it ???
Old May 19, 2007 | 03:04 PM
knob's Avatar
knob
Cruising
Do a search on ebay-there are several people that will send you a repaired, warrantied climate control for around $70 as long as you send your broken on in after you receive the new one. Easiest fix for this common c5 problem.
Old May 19, 2007 | 03:19 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Try this:
http://forums.corvetteforum.com/show...ht=dim+display
To climate control display
