Antivenom shift mod?
Old May 19, 2007 | 08:23 PM
spiral04's Avatar
spiral04
Default Antivenom shift mod?
I understand you use a washer to reduce the spring tension to reduce engagement pressure on the shifter. I have read to use a copper washer with a 3/4" inside diameter and at least a 1/8" thickness. The problem is I can't find copper anywhere. I do find brass. Will brass work? I found the exact size in brass. If brass will work, use two washers or one? TIA
Jason
Old May 19, 2007 | 08:47 PM
hk940's Avatar
hk940
copper, brass, 316ss. all should work
Old May 19, 2007 | 09:54 PM
MUKAK's Avatar
MUKAK
how exactly does this mod work? can some1 explain it to me?
Old May 19, 2007 | 10:13 PM
spiral04's Avatar
spiral04
I can't explain it well, but here is a previous thread that has helped many. In the thread there are also some other links which also may help out.
http://forums.corvetteforum.com/show...shift+bolt+mod
Old May 19, 2007 | 11:19 PM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
EXTREMELY easy mod to do. Go to PepBoys, AutoZone, etc, and pick up some copper washers. Once the car is off the ground, it takes less than 5 minutes to do the mod.
To Antivenom shift mod?
