[Z06] Z06 Tires
Old Oct 29, 2007 | 11:44 AM
zcobra1's Avatar
zcobra1
Originally Posted by 80shilling
I am running 295/35-17's in front and 315/30-18's in rear. I am lowered and have a track/street compromise on my alignment specs, all on stock wheels. Zero problems with rubbing. I just did a Sears Point HPDE and the car was freaking brilliant. The tires in that size, keep the correct front to rear differential and the correct rolling circumference... They are no more than .2" away from stock and almost identical the the Michelin PS2's in stock size in rolling circumference. Tire Rack has every spec you need, including ACTUAL tire height etc...
What brand of tire is this ?
