Can someone explain CAGS to me?
Old May 21, 2007 | 03:05 PM
HOOBS's Avatar
HOOBS
Default Can someone explain CAGS to me?
What is CAGS all about? Why does it make me go from 1-4? And how to disable it?
Old May 21, 2007 | 03:07 PM
max'svette's Avatar
max'svette
St. Jude Donor '11
It is a solenoid. That prevents you from getting into 2nd gear whenever you're at 25% or less throttle and around 2000rpms in 1st gear.
Some people pulled a fuse, others said it didn't work for them. You can also try to get a "bypass kit". Do a quick search by typing in CAGs and it will tell you more that you ever wanted to know.
Old May 21, 2007 | 03:11 PM
02MillenniumVette's Avatar
02MillenniumVette
If I remember correctly it was designed so you dont have to pay a gas guzzler tax on the Corvette. On a C5 I believe its between 1900-2400RPM's in first gear that it will force your to shift into 4th. When I had my Camaro SS I think it was between 2100-2600 RPM's. You can get the eliminator to get rid of it. Here is a link if you want to buy one.
Skip Shift
Old May 21, 2007 | 03:12 PM
Uncle John's Avatar
Uncle John
It had to do with avoiding the "gas guzzler" tax. It forces you to shift from 1 to 4 when you are in first gear between 14-21 mph (might be 14-19 mph). Anyway, buy a CAGS eliminator. Its just a little plug with a resistor that disables the CAGS feature that plugs in near the transmission. About $20.
CAGS = computer aided gear selection
Old May 21, 2007 | 03:18 PM
HOOBS's Avatar
HOOBS
Sounds interesting...it is a pain in the a$$
Old May 21, 2007 | 03:19 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Skip Shift
and to disable the CAGS stop driving like a ***** and give it some gas
Old May 21, 2007 | 03:20 PM
z064ddle's Avatar
z064ddle
GM installed it on the Vette, so that you don't have to pay Gas Guzzler tax on your car. Like the above poster said, there's a solenoid that prevent you from going from 1st to 2nd in low RPM. There're few things that you can do; if you select not to do any mods to your car then you would have to shift at a higher RPM; like above 3K. There're lots of vendors who sell a by-pass kit that you can plug in to disable the 1-4 shift. You can also make the kit yourself by adding a 2k ohms resistor to the connector to fool the computer.
Old May 21, 2007 | 03:21 PM
02MillenniumVette
To Can someone explain CAGS to me?
