I Need Advice Quick Please!!!
Old May 21, 2007 | 05:08 PM
photoguy's Avatar
photoguy
Default I Need Advice Quick Please!!!
I was driving today and got behind a line painter truck. When I got home I found I had white and yellow paint in my wheel wells and also some on the inner fenders and under the doors.
What can I use to take it off before it dries??
It seems to be a type of latex based paint.
Any help would be appreciated>
THANKS!!!
Old May 21, 2007 | 05:11 PM
FKING1's Avatar
FKING1
If it's Latex, a water spray may work. Otherwise, paint thinner.
pala's Avatar
pala
St. Jude Donor '07
Default that suxs
depends what kind of paint,,
first thing i would do is try some wd-40,, then wash n wax,,,,, use paint thinner at, last resort.
dont use paint thinner, i got some mineral spirits...
Old May 21, 2007 | 05:12 PM
photoguy's Avatar
photoguy
Will paint thinner hurt the coating on the mag red clear coat??
Old May 21, 2007 | 05:16 PM
elctroman's Avatar
elctroman
WD -40 wont hurt your paint or use kerosene
Old May 21, 2007 | 05:21 PM
thegame's Avatar
thegame
I'd hold of on the pain thinner untill more people chime in. I understand this is a time related issue but paint thinner sounds bad to me.
04cad's Avatar
04cad
St. Jude Donor '07-'08
Old May 21, 2007 | 05:24 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I would think it could. As mentioned above work with solvents with less high end chemicals such as WD-40 (fish oil), then maybe Kerosene, Then (and don't flame me as I have used gas on my paint with no harm done) Gasoline. I use Citrus Orange on my inner fender wells routinely but DON'T USE CITRUS ORANGE on either your paint or wheels as it can remove the clear coat. Good luck with the unwanted "detail" work.
max'svette's Avatar
max'svette
St. Jude Donor '11
SIMPLE GREEN! (worked wonders) Same thing happened on my old car... the week I was selling it of course. I had to use one of those "rougher" sponges thank god it was on the bottom of the car... but if it happened to the vette the paint on the bottom is very shiny, I'd think I would have permanent paint damage.
Old May 21, 2007 | 05:39 PM
GRUNIE's Avatar
GRUNIE
Goof Off in the yellow can. Available at Lowe's, Home Base most hardware stores. There's always a can on my work bench .
LMB-Z's Avatar
LMB-Z
Gasoline will work on the painted surface, just apply wax afterwards. It should work on the inner fender as well, I would just wash thoroughly with hot soapy water afterward. Splash a small amount of gasoline on a rag and rub. It may take some elbow grease but should come off.
Old May 21, 2007 | 05:42 PM
OsoBear's Avatar
OsoBear
If you don't have results with any of the above, call you insurance agent. Friend of mine had his insurance company remove paint from all over the front of his new car. They referred him to a body shop that specialized in removing overpaints. They did a beautiful job.
Shop was in Harrisburg I believe, kind of far for you. Sorry
Old May 21, 2007 | 05:51 PM
photoguy's Avatar
photoguy
Thanks all for the quick responses. I will give the old WD40 a try and let you know how it works. That seems to be the safest choice.
Old May 21, 2007 | 06:32 PM
photoguy's Avatar
photoguy
Well the WD40 did nothing to remove the paint on the body under the door. If I use my finger nail I can chip it away but I am worried about scratching the paint.
Any other thoughts?? It is starting to dry and is getting hard.
Old May 21, 2007 | 06:34 PM
photoguy's Avatar
photoguy
ttt
Old May 21, 2007 | 06:50 PM
thegame's Avatar
thegame
Maybe a stupid suggestion but how does bug and tar remover work since it's not totally dry yet ?
Old May 21, 2007 | 07:09 PM
elctroman's Avatar
elctroman
as i said before KEROSENE just wash it off when your done
To I Need Advice Quick Please!!!
Old May 21, 2007 | 07:25 PM
photoguy's Avatar
photoguy
Tried the tar remover and no go. Looks like Kerosene will be the next step.
Thanks!!
Old May 21, 2007 | 07:29 PM
Mike Mercury's Avatar
Mike Mercury
I had bright yellow highway line paint spattered all over my metallic green Caravan.
on advice of a friend, I took it to a "spray yourself" carwash and used the pressure wand. Holding it about 2 inches from the surface of the car - and at an angle (not straight on)... it took all of it off.
Old May 21, 2007 | 07:42 PM
photoguy's Avatar
photoguy
Thanks electoman. The Kerosene did the trick. Now i'm off to the local car wash to try to get the wheel wells clean!
