CLB install
May 21, 2007 | 08:23 PM
CLB install
How hard is the corvettes of houston Column Lock Bypass to install? I just bought it and was wondering what im in for here?
May 21, 2007 | 08:27 PM
Just did mine last week from Corvettes of Houston. 10 minutes. As easy as pie.
Chris
May 21, 2007 | 08:32 PM
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Might be a little tricky your first time, the only real challenge is locating the correct connector you need to separate and plug the CLB into.
Dropping the knee bolster (the only actual disassembly work) is easy.
But once you get it done, you'll realize how simple it is.
May 21, 2007 | 08:51 PM
Hardest part is taking off the access panel under the steering column. Other than that, its very easy.
May 21, 2007 | 09:01 PM
May 21, 2007 | 10:14 PM
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
It's so easy even a caveman can do it.
May 21, 2007 | 10:21 PM
Very easy. Do it, and do it now.
May 21, 2007 | 10:23 PM
St. Jude Donor '11
Took me about 40 min or so, 20min of which i was fighting with the interior temperature sensor... man that thing was a pain to get in/out.
May 21, 2007 | 10:34 PM
Quote:
Originally Posted by
old55
May 21, 2007 | 10:47 PM
max'svette
It took me about the same time and I have a hard time walking and chewing gum. I wish I had the pictures when I did mine last week.
May 22, 2007 | 12:06 AM
St. Jude Donor '08
WWK888
Easy to do. I used the above instructions also. You'll be fine!
