From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Originally Posted by mrm1149
could be the stem nut....also dealers are not too great at finding leaks, suggest what Zilla recommended. Have a GOOD tire shop check it for you.
When I had the tire shop check the tire you could barely see the bubbles from the very slow leak. The bubble looked like as if they were created by the applicator to apply the soapy water.
Park car in hyperbaric chamber. Tires will no longer lose air.
Short of the "hyperbaric" chamber trick....I bought a 5 Gallon Air Tank from an auto parts store and had Costco fill it with nitrogen. I have the Michelin PS2's and I use the tank to keep them up to pressure. I am not saying that the nitrogen will effect your pressure loss. Just the tank for air replacement until you find the leak. The tank is very inexpensive. You can also check Harbor Frieght as well for the air tank. I believe I got mine at a Pep Boys or Kragen...Good Luck
You might want to check the valve stems for air seepage!
If not you might be having a small object puncture in the tire somewhere! Do a very close inspection with soap and water and add a little extra air pressure for the test only!
Then if you find where it is leaking from reduce pressure to stock setting and fix as needed!
I had a hairline cract in a OEM wheel. Tank of water showed the leak. Replaced rim and no longer a problem. Friend had a bad schrader (sp?) valve and it did the same thing.
3. Take it to the dealer for the Bad Tire Leak recall.
or
4. (the best answer here, as many have already told you) Find the leak and get it repaired. It is the least costly and easiest to do ( other than not letting the car sit, which shouldn't be done anyway, regardless of the tire leak).
It's just a small leak the is probably around the valve stem and a small punture. Nothing that is not ordinary to all tires, not just Corvette tires.
