need help with shift booot/shift knob install PLEASE!!
Old May 23, 2007 | 12:09 PM
racer847's Avatar
racer847
Default need help with shift booot/shift **** install PLEASE!!
I bought a new shift boot and shift **** for my 00 manual c5. I cannot for the life of me get that metal wedge out of the top of the stock shifter in order to remove it. Im very very frustrated and desperte!! PLEASE HELP!!!!!!!!!!!!
Old May 23, 2007 | 12:14 PM
02MillenniumVette's Avatar
02MillenniumVette
See if this tech article helps any.
Shift ****
Old May 23, 2007 | 12:29 PM
racer847's Avatar
racer847
Default help
Ok ill try that, I was usuing vice grips but it just kept slipping off, now i have less to grab on as its worn some. what about drilling a small hole thru the center fo the wedge and inserting a machine screw in it thenm grabbing the screw to pull it out?? Ive got one hell of a stubborn one!!!
Old May 23, 2007 | 01:04 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Here's another link that might help:
http://www.vetteessentials.com/instr...t_install.html
Old May 23, 2007 | 01:06 PM
zeevette's Avatar
zeevette
The vice grip method works for lots of guys that have the demon key in moderately tight. If it's stuck good, the two large flat screwdriver method works better. Just place the two 'drivers on either side (narrow) of the key, and leverage the pin out. You might want to wrap the leather **** in a small towel to protect it, but it's kind of a POS anyway.
Old May 23, 2007 | 01:09 PM
02gt350's Avatar
02gt350
Mine was frozen in there. I tried all the articles guys posted here, no good. I had to drill small holes all around the demon key and pull it out with pliers. My buddy who is 450 pounds, was holding the shifter, I had teh key in a pair of vice grips, we pulled until i went flying across the yard, still didtn come out. You could have a bastard one like I did
Old May 23, 2007 | 01:31 PM
slvr bulit's Avatar
slvr bulit
Put a towel around the **** to protect it. Clamp on to pin with vice grips, use big screw driver to pry up on vice grips! Worked for me!!
Old May 23, 2007 | 02:07 PM
KidShalene's Avatar
KidShalene
Had to resort to the drill and machine screw myself, good luck......
Old May 23, 2007 | 02:12 PM
steve8's Avatar
steve8
Try a little wd-40.
When you do the vise grips, tap upwards with a hammer. This is a lot more effective than just pulling up.
Old May 23, 2007 | 03:16 PM
Bradc28's Avatar
Bradc28
I used this method and it came out relatively easy.
http://temp.corvetteforum.net/c5/pat...rInstall.shtml
Old May 23, 2007 | 03:24 PM
rws.1's Avatar
rws.1
put the vice grips with the jawsfacing the front and rear of the car.
grasp firmly.
Sharply tap the side ( passenger) of the vice grips towards the drivers side.,
As you sharply tap, simultaneously pull up on the vice grips as you wiggle then front to back ( like a densitst pulling a tooth) 3-4 sharp taps and it will be out guaranteed.
Old May 23, 2007 | 03:37 PM
racer847's Avatar
racer847
Default shift **** removal
thanks alot for all the input guys, mucho gratious. I will respond later tonite or tom and let you know how it went
Old May 23, 2007 | 03:41 PM
chai1836's Avatar
chai1836
Originally Posted by steve8
Try a little wd-40.
This worked for me...although it still took about 90 minutes to work loose
Old May 23, 2007 | 10:11 PM
I used the vice grips and tap up with a hammer method on mine - worked like a charm.
Old May 24, 2007 | 01:03 AM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Me too. Damn demon key!
Old May 24, 2007 | 11:18 AM
racer847's Avatar
racer847
Default got it!!!!!
ok I finally got it out last nite! I had to resort to drilling a hole in it and tapping a machine screw in it, then using the vice grips and a little bit of wd40 to get the sob out. I had a real stubbern one apparently. The new boot and **** looks awesome. Thanks again guys!!
To need help with shift booot/shift knob install PLEASE!!
