[Z06] Condensation in parking lights
Old Oct 23, 2001 | 02:06 AM
kh24's Avatar
kh24
Default Condensation in parking lights
I just got my z on 10/11 and while I was applying my zaino I noticed that there is condensation inside the parking lights/turn signals. :sad: I noticed it about a day after I got the car and it has remained there eversince. Every time I check the lights day or night there still is condensation on the inside. Anyone have any ideas on how to correct this. Why is it always there? Should I have the dealer replace the assembly?
Old Oct 23, 2001 | 07:14 AM
jimhoffman's Avatar
jimhoffman
7th Gear
Default Re: Condensation in parking lights (kh24)
I would definately have the dealer fix the problem, sounds like the seals
are leaking.
Jim
Old Oct 23, 2001 | 12:42 PM
GVETTE's Avatar
GVETTE
5th Gear
Hello maybe I can help you.I had the same problem on my 01 coupe.The dealer gladly replaced them under warrenty.I got the car back and the lights got condensation in them again.The dealer was unaware of a bulletin or a revised part for this.My advice to you is: if your dealer can assure you of the fix do it.If not don't.It was a complete waste of my time.Greg :bs
Old Oct 23, 2001 | 02:58 PM
Mark S.'s Avatar
Mark S.
kh24, are you parking your Z outside overnight?
Old Oct 23, 2001 | 11:36 PM
kh24's Avatar
kh24
Default Re: Condensation in parking lights (Mark S.)
The Z remains in the garage at all times when it is not being driven or washed. The condensation does vary through out the day, sometimes there is a lot and sometimes there is just a little bit, but it is always there.
Old Oct 24, 2001 | 08:56 AM
Mark S.'s Avatar
Mark S.
Joe, that's really weird...usually condensation occurs from leaving it outside. The dealer should be able to replace the seals...just watch them carefully.
Mark
To Condensation in parking lights
