shifter install question
Old May 24, 2007 | 11:01 PM
triple black c4's Avatar
triple black c4
Default shifter install question
I have been working on installing a new B & M shifter in my o2. After installing the shifter the instructions say to go through the gears and for some reason I cannot get it into reverse. Any of you ever have that problem? They have a help line but is not open now and I would like to get it finished up. Any Help appreciated. Thanks Ron
Old May 24, 2007 | 11:04 PM
Mrs. Patches's Avatar
Mrs. Patches
Cruising
You may want to try to loosen the shaft coupler and try to re-center the shifter into its neutral position. If the B&M shifter has a neutral adjusting pin, push that down, loosen the shaft coupler, re-center the shifter, re-tighten the coupler and pull up on the pin. (Don't tell Patches I told you...)
