Remove Front Bumper??
Old May 27, 2007 | 09:47 AM
vette dan's Avatar
vette dan
Vette Dan
Default Remove Front Bumper??
I know I've seen something somewhere on how to remove nose but now I can't find it???
Help Please
Old May 27, 2007 | 06:16 PM
vette dan's Avatar
vette dan
Vette Dan
ttt
Old May 27, 2007 | 06:21 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
What exaclty are you looking for?
There's bunch of screws and push pins that need to be removed.
Old May 27, 2007 | 08:55 PM
vette dan's Avatar
vette dan
Vette Dan
Don't mean to sound like a smart a$$. But I know that!
Steps to properly remove it.
Old May 27, 2007 | 09:57 PM
Z06ufgrad2002
Here it goes:
As per the manual:
raise and support the vehicle
remove the air deflector and the left and right outer valance
remove fascia to skid bar bolts
remove fascia to radiator support bolts
remove fascia to close out panels
remove the wheelhouse panel to fascia bolts
disconnect the fascia harness connector
remove the nuts fron the fender reinforcement studs
disconnect the front brake caliper cooling ducts from the fascia. Pull the fascia outward slightly to release the tension between the ducts and the fascia.
lower the vehicle
remove the fascia upper flange to fascia retainer push-pin and bolts
remove the fascia
HTH
Old May 27, 2007 | 10:25 PM
vette dan's Avatar
vette dan
Vette Dan
Thank you !!!!!
Old May 28, 2007 | 01:05 PM
Z06ufgrad2002
No problem
Old May 28, 2007 | 01:44 PM
Patches's Avatar
Patches
I have the illustrated version I can email if you need it.
Old May 28, 2007 | 03:01 PM
pjbracing's Avatar
pjbracing
Default Fog Light Insert Replace
I don't need to remove the bumper and the front facia but do you have directions to access the fog light insert so I can replace that easily. The only instructions I've gotten talk about looking for hidden screws! Any suggestions? and THANKS - Pete
Old May 28, 2007 | 03:56 PM
Patches's Avatar
Patches
Sure, Pete. PM me your email addy and I'll send it to you.
Old May 28, 2007 | 04:07 PM
Bob CTS's Avatar
Bob CTS
As Z06ufgrad2002 said, but I did not raise the car, it will look like this after:
To Remove Front Bumper??
