I will be installing tinted front corner lights soon. Are there any suggestions out there for bulbs that may be a little brighter than oem bulbs? I am leaning against installing LED's, per jdmvette's suggestion. Just looking for a high quality incandescant bulb. Any help would be appreciated. Thanks!
I'm using stock bulbs with mine, and the light comes through just fine. I'd see how they look with the stock bulb first, then change them if you think they're too dark.
And as far as legality goes, tinted is tinted. They're illegal. The cop isn't going to care if the light shows through or not.
I see you're running black-outs on the rear. So what's the big deal with the front?
I agree with you, but when I bought the rear blackouts, I went with the Halo's because they were brighter. I would like as close to oem as possible, just for the safety factor. I plan on putting all new bulbs in when I change out the corner lights, I'll probably go with the Silverstars.
