Dipstick calibration
Old May 30, 2007 | 06:05 PM
427435's Avatar
427435
Default Dipstick calibration
Changed oil the other day. Put in the 7 quarts and ran it for a while. The next day I checked the dipstick (on a level surface) and the oil level was at the bottom of the operating range. I didn't add another quart as I've heard of "mis-calibrated" dipsticks in other engines.
Has anyone else noticed this???
Old May 30, 2007 | 06:10 PM
bb609's Avatar
bb609
'03 Z06 - no issues here. 7 quarts puts it just over the full line on mine...and stays there.
Old May 30, 2007 | 06:43 PM
T VETTE's Avatar
T VETTE
6.5 quarts is full, you are over and not a good idea. Never heard of this dip stick issue before, but if you are sure it is in all the way see if a friend has one you can try to compare or get another or mark the stick for new full level.
Old May 30, 2007 | 06:48 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Calibration
I can see this thread taking a different direction.........................
Old May 30, 2007 | 07:16 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
You are fine with 7.0 quarts. No problem. As far as your original question goes:
Old May 30, 2007 | 07:42 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Just a note:
There are actually two (2) different dip sticks for the C5's.
The differences is approximately 1 1/2 inches in length.
Most of the 'shorter' ones are on the 97-98 engines.
Many of the 'longer' ones have been modified - this is due in part to owners ordering replacement (aftermarket) ones with the color or chrome 'handles'.
Old May 30, 2007 | 08:40 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Yup it certainly is...
Dial 1-900-dip-your-stick..
2004 Z06
I just changed my fluids and 7.0 quarts puts it right on the full line.
Old May 30, 2007 | 08:46 PM
moserbe's Avatar
moserbe
Damn, I have a 98 so I guess that I have the SHORT one!!
Old May 30, 2007 | 08:47 PM
Oldvetter's Avatar
Oldvetter
6.5 quarts of oil is the correct amount. If you don't raise the back of your car during draining oil, 4 ounces of old oil stays in the pan.
There are two different dip sticks. Early years show 6.5 quarts at the top of the hatched area, the normal full mark. Later years shows 6.5 quarts at the middle of the hatched area, normally the half-a-quart-low mark. This is why some owners of later year C5s overfill their cars by half a quart (7 quarts).
The owner's manual says you can overfill by one quart, if you are racing the car, but the extra oil should be drained out afterwards.
Old May 30, 2007 | 08:48 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Old May 30, 2007 | 09:10 PM
tellefan's Avatar
tellefan
I've always used 6.5 quarts with a new filter, and jacking up the rear end so all the oil drains out. David
Old May 30, 2007 | 09:12 PM
Blue260's Avatar
Blue260
04' and 6.5 qts fills mine to the top.
Old May 30, 2007 | 10:27 PM
427435's Avatar
427435
You're right on the 6.5 qts---and that's what I did put in. I remembered opening the 7th qt. when I posted this thread, but did only use half of it.
Good idea to do some comparing with another dipstick. I belong to a Corvette club so that shouldn't be too hard. Thanks for the idea.
To Dipstick calibration
