Under hood squeak
Old May 31, 2007 | 09:38 AM
DGW's Avatar
DGW
Default Under hood squeak
Where is the squeak coming from, and will an underdrive and new belt fix it?
Old May 31, 2007 | 10:01 AM
Pizzano's Avatar
Pizzano
Probably and most likely the Idler pulleys, there is 2 of them
very common, noise usually goes away after teh engine heats up (normally) that is, in your case it might not, easiest is just to replace them, not expensive at all for the do it your selfer.
Old May 31, 2007 | 10:26 AM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
I've heard gatorback belts help a lot.
If not, Pizzano is probably right.
I've also heard you may as well replace both.
Old May 31, 2007 | 10:57 AM
z06Bigbird's Avatar
z06Bigbird
Easter chicks????
Old May 31, 2007 | 12:40 PM
Hawg's Avatar
Hawg
I have a squeak as well...so I need a new serpentine and pulleys??
Old May 31, 2007 | 12:48 PM
wit2pz's Avatar
wit2pz
Guys, try changing your belts first. I went to Auto Zone and got a set of Gatorbacks. My chirp(squeak) went away after putting on the lower belt (AC serpentine).
I did mine myself(virtually), with the oversight of my neighbor...
Old Jun 1, 2007 | 09:22 AM
Hawg's Avatar
Hawg
To Under hood squeak
