Differential Fluid
Old May 31, 2007 | 10:00 PM
jbone's Avatar
jbone
Default Differential Fluid
Does anyone have a guide on how to change it and what is the recomended fluid to replace it with?
Old May 31, 2007 | 11:09 PM
Bret01Z06's Avatar
Bret01Z06
There is a plug on the back, open it up and let the fluid drain out. Then replace the fluid and put the plug back in. I like RedLine fluid, don't forget the limited slip additive.
Old Jun 1, 2007 | 12:17 AM
rws.1's Avatar
rws.1
from the C5 tech tips
https://www.corvetteforum.com/techti...=100&TopicID=1
there are two plugs a lower drain plug and an upper fill plug,
Make sure you can remove the fill plug before you remove the drain plug....
Synthetic 75W90 gear oil ( 2 containers) Mobil 1 is as good as any... + 4oz GM or aftermarket limited slip differential additive.... put it in first so there is no dosage issue.
Old Jun 1, 2007 | 03:25 AM
spiral04's Avatar
spiral04
For future reference. Thanks
Old Jun 1, 2007 | 05:41 AM
Corvette Don's Avatar
Corvette Don
I used royal purple for my engine, tranny and diff, the diff fluid already has the limited slip stuff
Old Jun 1, 2007 | 08:56 AM
The California Kid's Avatar
The California Kid
My 6 speed has ATF only Dexron IV, stamped right on the housing
Old Jun 1, 2007 | 09:39 AM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
That's Transmission fluid BTW, I switched to Royal purple for my trans, it seems to shift a little smoother
Old Jun 1, 2007 | 09:49 AM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
Royal purple here
Good stuff......
Old Jun 1, 2007 | 11:05 AM
sliebl's Avatar
sliebl
We just did ours with Amsoil SVG (Severe Gear) 75W90. Before the change we had some limited slip binding going on during tight turns. The car only has 24000 miles on it (2001 Coupe) but having just purchased it, we thought it prudent to change ALL of the fluids to get a baseline on when the services were performed and doing it yourself will save you $100's. The Amsoil SVG already has friction modifier built in so there is no need for additional additives. The Amsoil quickly improved the performance of the rear in tight maneuvers. No more hopping tires, or binding.
As mentioned above, there is a drain plug just forward of the rear leaf spring. The drain is in the rear 'cover' of the diff.
Get a hand pump ($10) to pump the gear oil in. I believe the diff holds about 1.8 quarts total. If you can change the engine oil, you can do the rear diff, and the M6 tranny. It's just as easy as the diff.
Another note, always remove the fill plug first to make sure you can get fluid back in after draining. You don't want to be 'stuck' with a seized fill plug and a drained diff.
Old Jun 1, 2007 | 11:57 AM
slvr bulit's Avatar
slvr bulit
Easy job! I used Royal Purple it already has the additive in it.
Old Jun 2, 2007 | 01:08 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
If you chose to go with AMSOIL, I'd recommmend the AMSOIL Severe Gear Extreme Pressure Synthetic 75w90. I've been using this fluid in my diff since the 04 season and haven't had a diff failure yet.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To Differential Fluid
