Gotta have tires - input needed
One of the best runflats made that are rated for all season use is the Michelin. It's also the only other extended mobility tire that can be repaired according to the manufacturer.Here's an article that might be an interesting read.....
click here!
Michelin run flats, no doubt! I got them from my CADILLAC dealership and they actually BEAT Costco's price! No problems with tp sensors and they even washed my 01 Vette and cleaned the wheels! Love these guys!
Oh, by they way the tires were great too! WAY better than the Goodyears run flats they replaced. good luck!
Torn between the Michelin Pilot Sport AS ZP and the KUMHO Ecsta ASX and possibly KUMHO Ecsta MX Run Flat.
This is my wifes daily driver and we are in Oklahoma. The KUMHO MX said not for near freezing temps and we are gonna have those!
Could sure use some input on this. Thanks!
Mich Pilot AS ZP have a 400 TW & AA A Trac rating so they should last a while.
Kumho ASX have a 420 TW & AA A trac rating........better for milage....
Kumho MX runflat have 220 TW &AA A trac rating......Nowt good milage...
If no one has ever explained TW & TR to you ,here you go.
Treadwear (TW) trac rating (TR) is a combination of how "hard" the rubber compound is vs. how it will keep traction on a skid pad under wet conditions.
TW test are done for 7200 mile with alignment & air pressure checked & fixed every 800 miles. A grade of 100 would indicate that the tire tread would last as long as the test tire, 200 would indicate the tread would last twice as long, 300 would indicate three times as long, etc.
With that in mind........most of those high dollar tires with a 220 TW will last an average of 14400 miles. the 420 treadwear tires will last an average of 30240 miles.
The next thing to look at is price!!!!!!
You know the TW & TR so why are tires priced so high? There are 2 very important reasons........Labor & advertizing. If labor is high & $$ is spent on advertizing........tire prices go up.
The last thing is prestege.........there are some guys that only drive the high $$ tires because they are convinced the tire is better than a cheaper tire. There is a quality difference in some but tires must pass FEDERAL testing before it can even be sold!!!!! OK now the prestage is there because those high $$ tires will have better traction in hard cornering & race conditions..........how many people really race their corvette........
Sorry for the long post but this question has been asked over & over & I can't remember anyone ever explaining TW & TR.......Good luck.
click here!
On a related isue, and someone can correct me if I'm wrong, I was told that a correct toe in leads to wear on the inside of the fronts. At least that is the dogma at my local vette club. My fronts are wearing on the inside, I accept that, and I only want to but ASX priced tires from that reason.
Thanks again !
