Hot/Cold A/C question?
Old Jun 1, 2007 | 12:14 PM
rare-72's Avatar
rare-72
Default Hot/Cold A/C question?
Now that the weather is getting hot here, I've noticed my A/C seems to cool better on the passenger side than on the drivers. What causes this? Do I need more refrigerant? I'd like both sides to be as. Thanks for any help or tips.
Old Jun 1, 2007 | 12:57 PM
Ron C!'s Avatar
Ron C!
Could be low refrigerant, but it could also be the control head. I just had the compressor, dryer, oriface and control head done on mine.
Old Jun 1, 2007 | 01:02 PM
T VETTE's Avatar
T VETTE
If it is cool on one side and not the other then it may be in the controls or dash area that directs flow. Freon is likely full if cool on one side.
Old Jun 1, 2007 | 01:24 PM
nickolbag's Avatar
nickolbag
Throwing any codes? Can't hurt to check them. Somebody may correct me if I'm wrong but I believe one possible sign of low refrigerant is cooler air on the passanger side. It just may be low on refrigerant. Checking the refrigerant and pulling codes would be the first things to do.
Old Jun 1, 2007 | 01:27 PM
LMB-Z's Avatar
LMB-Z
Mine is doing the same thing. Just had the control head replaced and freon checked.
It is also not throwing any codes
Old Jun 1, 2007 | 02:48 PM
T VETTE's Avatar
T VETTE
Still not solved??????
Old Jun 1, 2007 | 03:19 PM
nickolbag's Avatar
nickolbag
Could it be the evaporator coil?
Old Jun 2, 2007 | 10:06 AM
rare-72's Avatar
rare-72
I'm going to check the refrigerant tomorrow, and see if the car has any codes. I also read on the forum that pulling fuse number 27 would reset the A/C diverter doors. Anyone used this ideal with any success?
Old Jun 2, 2007 | 12:21 PM
BostonJoel's Avatar
BostonJoel
Mine did the same last summer. Replaced the control module and then it worked fine. $400. later........
Old Jun 2, 2007 | 01:46 PM
rare-72's Avatar
rare-72
I have a spare control module. Is it a pretty easy changeout?
Old Jun 2, 2007 | 04:10 PM
Jistari's Avatar
Jistari
http://forums.corvetteforum.com/show....php?t=1698740
Try that link. This guy seemed to really persue an AC problem so he hit all the possibles.
BTW, simple stuff (freon level, making sure the fins on the radiator are clean, checking when driving (rather than when standing still) . . .) often either clears up the problem or shows its not as bad as you first thought.
Old Jun 2, 2007 | 04:38 PM
INaband's Avatar
INaband
CI 7-8 Veteran
It's low on R134a...had same symptom, no codes..12oz did it..these systems only take 26 ounces...
Old Jun 2, 2007 | 05:22 PM
nickolbag's Avatar
nickolbag
HVAC control module isnt that hard to replace. Under the panel behind the glovebox. Its to the back right if your laying on the floor looking up. I think its 5.5mm bolts. Take the bottom bold out and just loosen the top 2. unplug the two plugs and slide it right out. Its simple to do just a pain in the *** to get to.
Old Jun 2, 2007 | 08:40 PM
rare-72's Avatar
rare-72
Thanks for all the tips guys!! First i'll check the refrigerant. Then I run down the list of items mentioned and post what fixed it.
Old Jun 2, 2007 | 09:57 PM
80vetla's Avatar
80vetla
same problem last month, low on freon was the fix!
To Hot/Cold A/C question?
